Anyone hydraulic roller running 7400+
Originally Posted by Reckless
Mike Brown runs his up to at least 7800 every time he races it.
https://ls1tech.com/forums/showthread.php?t=581911
Originally Posted by GrannySShifting
Just want to see who all out there is doing it. Have a couple up there and one that runs clean to 7700 rpm, makes great power doing so, but some crankcase/windage issues seem to be cropping up
there was a kid around here that had his limter set at 8100.. and it was in a 98 car.. with a cam and bottle.. needless to say he spun a bearing haha, it lasted for a couple years though..
Originally Posted by kossuth
You're pushing oil out of the filler hole in the valve cover? Doesn't sound to me like a windage problem as much as it does a drainback problem in the cylinder heads if I'm understanding you correctly.
Sounded like a crankcase pressure problem to me
PS thought about adding this, what do your blowby numbers look like if you've done a leakdown test while the engine is warm???
Originally Posted by SideStep
I was running to 7500 for about 4 months when I had my 232/236 XE-R cam....
Why? Was it making power up there? With that small of a head and camshaft id think it would be all out of steam 500 rpm or more before that. They sound mean buzzing though dont they!
I expect it to leak a bit maybe have to ask Eric on that one as loose as its ringed. Im temtped to hook up my pressure sensor to the crankcase and monitor that actual pressures inside under load. Im worried about it aerating the oil, maybe make a pull than drain ot and see if it looks like the foam mess
