pushrod length?
pushrod length?
Will the pushrods be stock length for the CNC LS6 heads and torquer II camshaft from TSP on normal GM head gaskets? I was unsure on this, and just wanted to clarify it would be the 7.4"
THANKS!
THANKS!
Do you know what the advertized base circle of that cam is? Standard LS1's are 19.7mm (That is a radius number--Double it if you measure it) If the difference is .6mm or greater you would want to adjust pushrod length.
