Cam swap with heads on?? Special tool for holding lifters??
Old 10-03-2006, 09:37 PM
pwrtrip75's Avatar
Default Cam swap with heads on?? Special tool for holding lifters??
I had a bad lifter so replaced the cam. I have 1 head off and the other side while spinning the cam could not get the lifters to stay up in the tray. What I did was tilted the car past 45 degrees and stuck a magnet in one...and luckily it worked. Is there a tool or some method to safely keep the lifters held up?
Someone told me they use a 5/16 rod?? or a JPR tool ?? what is that?
anyone got a write up or some pics?
thanks.
Old 10-03-2006, 09:45 PM
OneMeanZ's Avatar
http://www.thunderracing.com/catalog...&vid=3&pcid=17
Down towards the bottom of the page
Picture of the tool
http://www.ls1howto.com/howto/fbody/...alljprtool.jpg
Old 10-03-2006, 10:16 PM
BriancWS6's Avatar
I used the pen magnet trick on my previous car when I went cam only. Worked great, and I even took them all back to Auto Zone afterwards They seriously didn't care.
Old 10-03-2006, 10:47 PM
zspot98's Avatar
Wooden dowel from Lowe's worked like a charm and it was only a couple of bucks.
Old 10-03-2006, 10:55 PM
HOSS's Avatar
use the dowels from lowes, cut them to 24 inches i think and you are good
Old 10-03-2006, 11:08 PM
mvvette97's Avatar
the wooden dowels are 5/16 aren't they?
Old 10-04-2006, 01:54 PM
zspot98's Avatar
Yea, I'm pretty sure they are. You might have to sand the one for the passenger side down a little, but these will work as well as the metal ones.
Old 10-04-2006, 02:02 PM
Bad Blue WS6's Avatar
www.LS1howto.com GREAT write ups with EXCELLENT pics for your needs. I think they decribe 3 ways to do it,,the pen mehtod being one, the cam tool form thunder racing being another,,cant remember the third.
Old 10-04-2006, 02:10 PM
Somebody09's Avatar
You're welcome!
Old 10-04-2006, 02:55 PM
ArrestMeRed99Z28's Avatar
you can also use hard brake lines. Just as cheap as the wooden dowels and you don't have to stick a peice of wood inside your engine!
Old 10-04-2006, 03:52 PM
mvvette97's Avatar
I was thinking about that. Would it be st to use the 5/16 brake line or smaller? I noticed alot of people when they use a metal rod they grind the end to a point. Is that needed?
Old 10-04-2006, 06:05 PM
dnm12's Avatar
oh yeah what about this photo!!!
check my sig on page 6 for a shoot load more photos
Old 10-04-2006, 06:15 PM
ShadowLightCSU's Avatar
lol now that looks easiest by far!
Old 10-04-2006, 06:18 PM
mvvette97's Avatar
great picture. Are those the 5/16? I heard some people using 1/4 but I would think the lifter may slide past
Old 10-04-2006, 08:56 PM
BriGuy's Avatar
I have used 5/16" wooden dowels in the past. Although after thinking about it more and seeing post on here, I don't want to take the chance of the wooden dowels breaking while in there. So today I went to Lowe's and bought some 5/16" metal rods that I will have cut to the proper length. And they cost me $7.60 for the two. I like the piece of mind though knowing that they won't break in there.
Old 10-04-2006, 11:09 PM
dnm12's Avatar
yep what ever works, mine were 5/16 that i dremeled down one side flat and then cleaned them and then rubbed them in oil and slid them on in there
Old 10-04-2006, 11:28 PM
Slo_240sx's Avatar
You ***
Old 10-05-2006, 08:50 AM
V6 Bird's Avatar
Theres no way in hell id use a wooden dowel...What are you going to do when you break it off...I use metal ones with the passenger side sanded down a hair to creat an edge.
Old 10-06-2006, 12:25 AM
mvvette97's Avatar
Just wondering, why do some people grind a flat area on the rods? Does that have to be done to work?
Old 10-06-2006, 09:57 AM
dnm12's Avatar
yeah otherwise it wont slip in, look get your lifters up it doesn't matter how
Quick Reply: Cam swap with heads on?? Special tool for holding lifters??
