What thread is oil feed on a ITS turbo ?
Old 10-04-2006, 11:07 AM
stevieturbo's Avatar
Default What thread is oil feed on a ITS turbo ?
As title...
For a T60 ot T70 DBB type.
Need to order up an adaptor for one.
Old 10-04-2006, 10:25 PM
Restricted User
NOSjohn's Avatar
Not sure what you're asking but normally the feed supply fitting we use on a turbo is 1/8 and -4an.
Old 10-05-2006, 01:02 AM
I assume thats 1/8 NPT then ???? ( 1/8 BSP would be more common in the UK, although most stuff is metric )
The fitting they supplied ages ago, is -3 on one side, and unknown on the turbo side.
I need to source a -4 fitting as you say, so I can hook it up to the engine, as thats the size of the adaptor in the block.
Sorting a -3 fitting for the block might be awkward too.
Old 10-05-2006, 01:50 AM
KissMySSo1's Avatar
pretty sure its 1/4" npt. if not 3/8" npt. but almost 100% its 1/4". its def not 1/8
Old 10-05-2006, 09:35 AM
Restricted User
NOSjohn's Avatar
Yes - 1/8NPT on one side and -4AN on the other side. If you buy your fitting from a decent turbo shop, this is what you'll get and this is the standard for a t3 and t4 turbo.
