Lot of Parts needed
Lot of Parts needed
1. 98-02 camaro or trans am oil pan
2. stock rods
3. 99-06 Coil packs with bracket and wiring
4. 99-02 camaro trans am engine wiring harness
5. Hardened Push rods 7.400
6. 98-02 camaro trans am throttle body
7. 98-02 camaro trans am mass air
8. 97-98 corvette fuel rail with regulator
9. ls1 starter
10. 98-02 camaro trans am alternator
11. ls6 oil pump
12. timing chain
13. lifters with plastic holders
14. rockers with shaft and bolts
15. center bolt valve covers
16. front, rear, and top engine covers
17. ls6 intake
2. stock rods
9. ls1 starter
11. ls6 oil pump
12. timing chain
17. ls6 intake
Originally Posted by ls1coupe
1.
2. stock rods
12. timing chain
2. stock rods
12. timing chain
MASS seller approved
11. ls6 oil pump
11. ls6 oil pump
The lifters are brand new OEM from GM.
I might be missing two rockers to make a complete set, I can double check and see how many I have.
Let me know
