Oil use after H/C install
Just curious if anyone has had this problem.
Before the H/C install the car used almost one qt of oil every 3,000miles
After the H/C install its now using 1 qt every 200miles.
I know I really need to do a compression check but I think its more in the Heads. Would bad Valve seals or a bad guide make it use that much?
Originally Posted by Slowhawk
no sealant on the rocker bolts
A few ideas.
A few ideas.
Not leaking oil anywhere and it doesn't appear to be getting in the coolant.
It mostly smokes on start up and if I've been putting around. If I run it hard I don't notice it once its cleaned out.
Slowhawk,
Now that you've said that I never put any sealant on the rocker bolts when putting it back together. I'll be putting H/S rockers on it this weekend should I just use a thread locker or use the black rtv?
I'll also be putting a catch can onit and be looking at the seals.
If its a bad tune and the rings are fluttering how bad is that if I've put about 3,000miles on it since the tune.
Originally Posted by slvrhwk
Thanks for the posts.
Slowhawk,
Slowhawk,
The thread sealer is a white paste. I guess it's working, I see no blue smoke and my oil level seems consistent.
PS don't ingest any of the thread sealer. It tastes like **** and it's hard to wash away from your mouth.
I'm having the exact same problem...burning M1 faster than I like...
Here's my thread...
Oil consumption...
Here's my thread...
Oil consumption...
