Can I install oil pump without removing pan?
Old 10-05-2006, 11:28 AM
Moderator
Black LS1 T/A's Avatar
Default Can I install oil pump without removing pan?
With the engine in the car, can I remove and install a new oil pump without raising the engine and/or removing pan? If I must, does anyone know the procedure or where I can find it?
I searched for an answer, but just can't seem to find a thread.
If you know of one, that would be helpful, too.
Thanks!
Old 10-05-2006, 11:34 AM
oange ss's Avatar
yes..LS1howto.com
Old 10-05-2006, 12:02 PM
ShevrolayZ28's Avatar
I'm quite sure you'll have to undo the oil pan, but there is no need to raise the motor.
Old 10-05-2006, 12:10 PM
HeapaShifter's Avatar
I do it without loosening the pan at all. You just have to be careful with the pickup tube bolt and use a short wrench and magnet.
Old 10-05-2006, 12:14 PM
GregWS6&z28's Avatar
when i did my pump I couldnt see how it could be done without lowering the pan all the way. I did it without removing the bolts, just enough for the pan to hang low
Old 10-05-2006, 03:07 PM
dnm12's Avatar
yes is the answer your looking for you just need to losen all the bolt on the pan including those that go from tranny into the pan
Old 10-06-2006, 05:51 PM
Moderator
You guys that gave me the straight-forward, simple answers and your experiences ... thanks. I know the deal now, right away.
And when I get to bustin' my knuckes ... also, thanks for the link to the writeup.
You guys rock!
Old 10-06-2006, 08:02 PM
TOS98SS's Avatar
I found it to be much easier to drop the pan . I would rather take out 6-10 easy bolts than have to fight with 1
Old 10-07-2006, 06:55 AM
Moderator
So the pan will come out without raising the engine?
Old 10-07-2006, 07:18 AM
Moderator
davered00ss's Avatar
ls1howto.com under cam install. you need to loosen all the bolts to the pan and lower it. Don't forget the ones on the bell housing.
Old 10-07-2006, 07:38 AM
TOS98SS's Avatar
You only need to drop it a few inces check ls1howto.com it explans the procedure its not bad at all but without droping it it looks almost imposable you will see
Quick Reply: Can I install oil pump without removing pan?
