F1 or F1-R on 8.5:1 383 LT1??
Anyone done this or know where I can get some info on it? Currently the car is running a Vortech V1-T trim with a cog belt making 17lbs. I am having consistent belt issues (Blower bracket flexing under boost and walking the belt off towards the front of the car) Especially when I spray the nitrous on top of the boost. About to give up on the Vortech if I can't find any other solutions and try the ATI. Any pics/help/feedback would be cool...
you can fit an F1 if you notch the block. i think to fit thr F1R you will need a custom bracket made. you should be able to have a shop fab up some more support for your vortech bracket to eliminate flexing. that is what i did because the D1SC bracket will flex a little also.
