My sheetmetal gas tank fills like it has vapor lock
Old 10-06-2006, 01:21 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
Default My sheetmetal gas tank fills like it has vapor lock
I have a sheetmetal gas tank, and everytime I put gas in it it acts like it's vapor locked. So I have fill, stop, fill, stop. Meanwhile it also spills some out. Anyone know why it does this? I guess I will have to drop it and see if the vent is messed up...
Old 10-06-2006, 02:02 PM
MrDude_1's Avatar
could you be more specific on what its doing?
i think you already know the first thing to look at.. the tank vent.
PSJ bobbleheads will be availible soon.
can i pre order?
Old 10-06-2006, 02:29 PM
LS1Tech Co-Founder
Originally Posted by MrDude_1
Blah blah blah
When I go to fill it, the gas backs up in the filler neck and I have to stop. I have a CAS gas tank.
blah blah blah
Yeah, I guess I can check the vent, I wonder how they should be set up?
Or it gets the hose again!
Stop stalking me.
Old 10-06-2006, 08:16 PM
Coal Mining Director
onfire's Avatar
The vent is plugged or has a low spot that has filled with fuel (like a gooseneck in the pipe below the sink...made to plug with water to keep sewer fumes out of the room).
You need to bring the vent hose straight up from the tank port (no loops)...I'd take it to the filler hose at the cap.
Old 10-08-2006, 02:52 PM
TS6
TS6's Avatar
Mine is doing this too, I think I have a low spot in the vent hose.
Old 10-08-2006, 11:22 PM
kp
kp's Avatar
My loops are a little under the filler neck and I can fill my tank full blast from a gas station pump. I'm kinda different though
Old 10-08-2006, 11:48 PM
2001-WS6's Avatar
I refer to it as the CAS Burp. Mine will shut the pump down at 10 gallons. Then feed it another 4 gallons more after the Burp.
Rick
Old 10-09-2006, 02:14 PM
LS1Tech Co-Founder
What causes it? It's very annoying.
Old 10-09-2006, 07:24 PM
kp
kp's Avatar
Its just too much fuel going in and the air in the tank not getting out fast enough. You either need a bigger vent or your vent is too low, the CAS tank I have here used the stock 99+ sender/vent and thats only like 1/4 inch. I dont know how yours is done but I have a 3/8 vent and it seems to work OK.
Old 10-09-2006, 07:39 PM
JMBLOWNWS6's Avatar
I am going to take pics of what I had to do with the nasty performance tank tomorrow. I fill away @ the pump with no problems at all! Yes I will finally take the dam pics LOL
Old 10-09-2006, 09:23 PM
LS1Tech Co-Founder
I have a CAS tank and the 99+ sender stuff. Can I modify the vent you guys think?
Thanks for replying.
Old 10-09-2006, 09:28 PM
kp
kp's Avatar
Depends what they used for a vent, if they used the 98 vent from the steel tank thats the problem, it wont vent unless there is like 8psi in the tank. Have to drop the tank and see what you have there..
Old 10-10-2006, 12:02 PM
LS1Tech Co-Founder
Okay I will do that after this Saturday, I hope to race then.
Old 10-11-2006, 12:58 PM
smokinHawk's Avatar
what do you guys use for vents?
if it tips over will it leak?
Old 10-11-2006, 01:19 PM
kp
kp's Avatar
I'm using a -6 rollover valve so I hope it doesnt leak, not going to turn the car over to test it though
Old 10-11-2006, 09:24 PM
SPEEDYws6's Avatar
I'm guessing that these tanks eliminate the charcole canister and vent solenoid, and the rest of EVAP for that matter?
Old 10-12-2006, 08:37 AM
LS1Tech Co-Founder
Correct.
Old 10-12-2006, 11:03 AM
koji777's Avatar
Post Pixs Of What You Did To The Nasty Tank Please!!!!!!!!
Old 10-12-2006, 06:23 PM
Gun5's Avatar
same here, started spilling all over i was like ****
Old 10-13-2006, 09:23 AM
JMBLOWNWS6's Avatar
Ill post them Monday. I am sick right now and cant do anything till Monday anyway. Car is finished and ready to be put back on the road. Are you guys saying you cant fill it all the way up? Or you cant put gas @ the pump without going real slow? FYI I have never filled it up. I put in about 9 gallons @ the pump no problems. Is that the problems you guys are having? So Ive been super busy trying to get my car done for Midnight madness this month.
