Pully seal on Vortech leaking
Old 10-06-2006, 03:40 PM
MavrikTA's Avatar
Default Pully seal on Vortech leaking
Well, as most of yall know, after MUCH research and MANY questions(thank all of you, by the way ) I finally decided on a Vortech aftercooled system for my T/A. I purchased this system used and just recieved the parts today. I noticed the the seal behind the pulley is weeping. What are my options to repair this? Where can I get a seal? Or is this just the nature of the beast and small leaks are ok. Its not bad, id just rather replace the seal if I can. I called Vortech and they wont sell any seals or bearings.
Any advise?
Old 10-06-2006, 06:43 PM
JMBLOWNWS6's Avatar
I have replaced 3 seals so far. Got them off ebay.
Old 10-06-2006, 08:25 PM
frbrd7996's Avatar
Let me know what you do,and where to get the parts,because mine is leeking too.Vortech told you they won't sell you any parts why that's a bunch of B.S.
Old 10-06-2006, 11:13 PM
C.W.A's Avatar
my procharger did the same thing...I called ECS and EPP and they told the part#! check witha supporting vender you'll have better luck!
easy fix!
Quick Reply: Pully seal on Vortech leaking
