getting pcm reprogrammed...
so...after seaching thru some threads on this forums and others...along with speartech website....these are my list to be done...
-disabling vats
-disabling all unnecessary emissions equipment
-lowering the fan turn on temp
-raise rev limiter
-change rear end ratio to match my rear end
-remove speed governor
-any other performance enhancement
car will only have intake/header/exhaust...
am i missing anything else??? and how much should i expect to pay a local shop to do this???
-disabling vats
-raise rev limiter
Originally Posted by G-Body
Wow, I didn`t know that. How does it work with a 6spd? does it pull out advance when you push in the clutch or at a pre-programmed RPM?
ok...i'm stoopid here...are u being sarcastic or seriously asking??? cuz i don't fully get the concept torque management...first time i've heard of such technology...
sawzall wielding director
-disabling vats
-raise rev limiter
-disabling vats
-raise rev limiter
Originally Posted by vanilla89
i sent mine to pcm4less and he hooked it up $265
i talked to hpe here in houston and they say they'll proramming it for partial cost of full tuning (dyno and programming) and i can pay the rest when i bring it back to dyno...they say their package ish 400...
