New best and then BOOM ***videos and pics***
Old 10-08-2006, 11:19 AM
LTLHOMER's Avatar
Default New best and then BOOM ***videos and pics***
Here are the vids:
http://files.filefront.com/blown+up+.../fileinfo.html
http://files.filefront.com/8secpass+.../fileinfo.html
8.781 at 161.00 on the limiter through the traps. 1.358 60 ft. 3393 lbs.
Pics of the carnage (more to come when it's pulled apart today):
New tune was spot on...but the stock oiling just wasn't up the task it would appear.
Old 10-08-2006, 11:26 AM
TS6
TS6's Avatar
At least you didn't drive through the oil and lose it, could have been much worse.
So now what, dry sump?
Old 10-08-2006, 11:28 AM
Navy David SS's Avatar
Congrats on the 8's, but to bad it came at the expense of your engine. Re-build time? Dry sump next time? Sounds like you were really flying.
David
Old 10-08-2006, 11:30 AM
LTLHOMER's Avatar
I did go through my oil and almost hit the wall about 10 times...it was bad every time I touched the brakes the car would try to spin. It could have been much worse though but I did my best to stop and not hit anything.
LS2Camaro's Avatar
Damn man that really sux, but hell of a nice run at least. If your going to go out, that is the way to do it with a killer run.
Old 10-08-2006, 11:32 AM
LTLHOMER's Avatar
Oh yeh get this...my best before was 9.0 at 155 and that was on almost 26 lbs...new tune-up from Don Bailey and I picked up HUGE at only 21 lbs of boost. Compared to my previous 21 lb numbers, I picked up almost 7 mph to the 1/8th (1/4 was only 6 because I was on the limiter but it would have went 163 I am guessing).
Old 10-08-2006, 11:33 AM
Louie83's Avatar
That was a lot of smoke. Darn.
Build her up better and stronger!
Old 10-08-2006, 11:51 AM
FormulaFire's Avatar
Damn.. I can only comapre this event to.. My favorite superhero dying. But damn.. that 8.7 was SOO SWEET!
Old 10-08-2006, 12:04 PM
What was different about this tune that allowed you to pick up so much? How much timing?
Old 10-08-2006, 12:06 PM
LTLHOMER's Avatar
Not much more timing but it was put in the right spots...the a/f was perfect on his first try...the driveability was a dream too...Bailey is the man I'll never go elsewhere for tuning needs.
Old 10-08-2006, 12:11 PM
~JOSHUA's Avatar
Dayam!
That was cooking!
Time to pay the piper though. I wish you luck...
Old 10-08-2006, 12:15 PM
GrannySShifting's Avatar
what was the setup and failure cause?
Old 10-08-2006, 12:22 PM
LTLHOMER's Avatar
Just a 347 with a bunch of used stock parts (heads, crank, block) and some used good parts (eagle rods) and add a little oil starvation and boom there goes a rod out the bottom of the oil pan. It was turning 8200 on the limiter on the previous pass so maybe the high rpm was part of the problem as well?
Old 10-08-2006, 12:30 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,087 Likes on 716 Posts
Spun to 8200 eh... Nice.
When I saw your boom video it looked pretty scary. Where you the car in right lane in Taner's vid that got super loose at the end of the track?
How did you hook up with Don, I thought he lived in the South 'burbs of Chicago.
Old 10-08-2006, 12:33 PM
The last comment on the "boom" video says it all. Bigger and better - 8200 limiter - good grief that spinning it.
David
Old 10-08-2006, 12:55 PM
Outlaw 10.5 Director
FSTR-THANU's Avatar
I can hook you up with an Aviad 4 stage pump!
Tom
Old 10-08-2006, 12:56 PM
frcefed98's Avatar
Glad you were able to get it stopped "safely"
8's....outrageous
Old 10-08-2006, 12:58 PM
navymitch12's Avatar
wow!!!!!
that is no good!
but good to see you didnt hit any walls
Old 10-08-2006, 01:19 PM
2001-WS6's Avatar
Wow... sorry to hear about the motor Sean. Congrats on getting the new best though.
Rick
Old 10-08-2006, 01:44 PM
Mike00ss's Avatar
Damn!
Quick Reply: New best and then BOOM ***videos and pics***
