Head/machine shop to look at
a bad head. I have a head that was leaking oil on the #5 cylinder down in the chamber causing the head to smoke. I wanted to get the head checked out and see if it's fixable etc (not valve seals or anything like that. Either spring pocket got ported into or something along those lines) Just looking at suggestions of who to take it to.
Thanks,
Nate.
Thanks,
Nate.
Thanks,
Nate.
Thanks,
Nate.
Originally Posted by skipperbisket
Mike Smith is in north fort worth off I35, i wouldn't have them do any work for me ever, but if you just need it checked out to make sure its true then they could surely take care of that.
most likely the valve seats right? i'm sure they could probably handle that there.... i just wouldn't have them doing any port work or anything like that.
Just take it to Mike Smiths Nate, Matt doesn't know what the **** he's talking about. Smiths did all the nachine work on my motor this time around, just tell them that I sent you.
Mark...i work right next to MSMS and i've met many people with stories about how they fucked ports up, lost power with msms ported heads, and many several that had failures due to poor attention to detail.
WE talked alittle about this last night Nate when he was at my his...My buddy that is.
He mentioned a crack, bad guide, and something else. I see him all the time and he said to bring it on. So its up to you man.
I'll try and figure out a time to drop em off man. Drop em off at your hizzouse or does he have a shop?
You home at all during the day? I could drop by after leaving UTA one day.
