Throttle body bypass..
does anyone know exactly what is needed to conect the 2 coolant hoses...
i just went to home depot, but the brass barbed i picked up was to big
so does anyone know the size and ect..so i could go in there and ask a worker for whatever i need..already got the clamps...well thanks for the help
l
l
Just buy a 5/16" hose about 2.5 feet long. I did 2.5 so that the hose would have no possibility of interfering with the belts, just had it run along the radiator hose and then turn at the second hole. One size is good for both holes. It will be a tight fit on the radiator hole, but as long as you get enough on there to put on a worm clamp you're good.
Originally Posted by CASHss99
do you need to block the TB holes
Old post but, any answer on what size connector? I dont want to run a single hose. Also does it matter if it is brass? Only $2.00 at home depot. The BMR one is aluminum I think; any benefit?
