Fuel flow requirements
I have stock 98 vette fuel rails,-6AN feed and return lines,stock rail mounted regulator, 60# injectors, 255 fuel pump, Will this supply enough fuel for my stock block LSx with pt76gts turbo, 6-8# boost meth/water injection? THANKS
Should be plenty. That's basically the same setup I have on mine. I don't have the AN lines (the stock v6 feed line is the same size but the return line is smaller). I'm also running a BAP but haven't had to turn it up yet.
The most restrictive parts were the two quick-connect fittings I used on the line at the engine. Checked those a couple of weeks ago, and they necked down to 1/4" where the rubber line slips onto the fitting. So I opened those back up to almost the full 3/8" again (by drilling them out).
If you're using methanol, which provides part of the fuel enrichment, that takes some more load off the fuel system too.
