clutch problems?
Old 10-10-2006, 06:53 PM
1gen's Avatar
Default clutch problems?
I've recently had a problem with starting my car after its been sitting for a full day, the problem seems to be with my clutch in that when I'm trying to start it putting the clutch all the way to the floor lights come on but it acts like I'm not putting in the clutch (lights on, no motor movement) but after I pump it a couple of times itll start. Now the first thing I thought was my fluid level, checked it and its fine, anyone got ideas?
Old 10-10-2006, 11:19 PM
jdoyle's Avatar
i was just reading on a remote start install and heard about a clutch relay, is that still good?
BTW: i dont know anything at all about this kind of stuff. but who knows.
Old 10-11-2006, 01:29 AM
staringback05's Avatar
is it a new clutch or has been replaced before?.....if so was it bled properly?
Old 10-11-2006, 02:04 AM
B-RAD2's Avatar
Mine does the same thing and this is the 2nd clutch in the car.... don't know what it is
Old 10-11-2006, 02:09 AM
geez like i said how is the install done? are the proper techniques being used?
Old 10-11-2006, 07:21 AM
trackbird's Avatar
Does the starter motor try to move the car, or does it "do nothing"? If it's doing nothing at all (other than the dash lights), it might be a bad clutch switch on the pedal assembly. Look above the clutch pedal, you'll see a button that is depressed by the clutch. That tells the car you have the clutch pressed in. If the switch is bad, it won't start. Just something else to check.
Old 10-11-2006, 09:40 AM
1gen's Avatar
its "do nothing" and its the original clutch, car only has 33K miles
Old 10-11-2006, 10:27 AM
hows the fluid level?....thats not that many miles for a clutch to be going out unless youve been dumping it alot
Old 10-11-2006, 02:25 PM
trackbird's Avatar
If it does nothing when you turn the key, and you give it a few pumps and it starts, I'm guessing you have a bad clutch switch (the one that is mounted above the pedal). You'll see it up there (once you pull the plastic trim panel down). See if you can test it with a volt meter or try a replacement one.
Old 11-28-2006, 10:58 AM
1gen's Avatar
it was a clutch switch a "clutch position sensor" got at the dealership for 11.25
