GM's, Viper's and Ford's T-56 ?s.
Old 10-10-2006, 08:26 PM
Stampede4ever's Avatar
Default GM's, Viper's and Ford's T-56 ?s.
I have some basic ?s, does each on the trans share the same bolt pattern for the bellhousings?
Is it possible to use the Viper's, Mustang's, and or the GTO's tailhousing, and what does it take?
And is possible to use the Mustang's, GTO's or the Viper input shaft, and what needs to be done?
All these ?s are based on using the Camaro's T-56.
Thanks.
Old 10-10-2006, 09:49 PM
wrencher
wrencher's Avatar
No peices are different.
The F-body tail has a torque mount provision.
The LS1 front housing the slave cylinder mount.
The main case I believe has differences among MFG's as well.
Old 10-10-2006, 10:18 PM
brujo98ss's Avatar
the viper has a 30 spline output shaft
you would have to replace the yoke on the drive shaft with one that fits the output shaft on the transmission
