Generation IV Internal Engine - Can you make L92 heads fit a 3.905 bore?
snketr
10-11-2006, 10:19 AM
Couldn't you weld the chambers? Or would they still be way to much overkill for the motor? Just seeing what you thought.
WKMCD
10-11-2006, 10:44 AM
Only if you dont mind the intake valve hitting the wall of the cylinder.
snketr
10-11-2006, 10:53 AM
Guess that answers that question. Thanks.
texinteg
10-11-2006, 10:58 AM
who minds that? Wouldnt that help performance? :jest:
malibu9in
10-11-2006, 11:09 AM
dosent the aftermarket already make killer heads for the ls1?
MrDude_1
10-11-2006, 12:38 PM
not the same flow for the same price.
gun5l1ng3r
10-11-2006, 12:43 PM
So would the new great deal be a Alu. LS2(I don't know the bore) block w/ l92 heads?
Are the valves too heavy in the L92 heads to rev to high RPMs?
Bandit28
10-11-2006, 01:57 PM
That does add performance! Sweet dude goodluck!
WKMCD
10-11-2006, 02:49 PM
We start assembling an LS2 402 for my C5 this weekend. We have all the parts now.
SPDC LS2 402 2cc pistons
L92 heads
L76 Intake
Comp 921's
Bret Bauer cam spec'd for this setup
Rams Dual disc clutch
American Racing 1 7/8 headers
42 lb Green Top injectors
Revised LS7 lifters
etc
etc
etc
Assembly/Installation and SD tune by Phil Thomas aka PHIL99VETTE
Not cheap to do it right but should be very interesting.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
