Do a Steel or Aluminum flywheel?? ls1 Fbody
I need a new clutch, just wondering if its better to do a steel or Alum flywheel?
Im thinking about doing the spec 3+
Its not a daily driver, and mostly drivin on the street.
pushing 550hp at the wheels.
Need something that bites! i burnt a regular spec 3
Got the same thing you got.... I had the steel one installed due to the fact that the car is full weight and had herd that it would be better for my application. I can't confirm or deny this tidbit. I went with the safe than sorry road. I heard that the aluminium was harder to get going, so I put on the steel one due to the stop and go traffic im in. I would also too like to know if the aluminium is mostly the same or if it's that much different....
Aluminum flywheels are different to drive on the street due to the loss of weight. Stock flywheels are heavy so that when you relase the clutch it has momentium to move the car. Aluminum will rev like crazy though and are great for drag racing not so good for road racing
What do you mean takes more to get car started? You mean start up, or do you mean get up and go from a full stop. And if so, why would this happen?
I daily drive, but would like the extra fun factor
Here's how I see it:
Due to the "less mass" of an aluminum flywheel, the engine will both REV and DE-REV quicker.
Takeoffs need more engine revs and clutch time to get going.
To get a feel of how it effects takeoff from a standing start with a manual transmission,
try taking off in 2nd gear, all day. That gets old fast and puts a lot of strain on the clutch.
Going back to 1st gear takeoffs brings back the happy.
Now it seems to me that to get an aluminum flywheel to be viable on the street, you need to
go to a smaller pinion and or a larger ring gear in the rear, say from a 3.42 to a 4.56 (or more).
Perhaps the guys running automatic transmissions with high stall speed converters (3000+)
could use a lighter flywheel (flexplate) as their engines are up in the meaty part of their engine's
torque band on takeoff and they have the added flywheel effect from a crankshaft spinning at a higher RPM.
Paul
Paul
Kleeborp the Moderator™
Theox - you have a point, but the viability of aluminum on the street is better than you are indicating (after all, a 3.42 to 4.56 swap is a BIG change). I'm still on the 3.42s with my aluminum flywheel setup (my new clutch weighs ~20lbs less than my old one), and I drive this car every day. You do have to implement a different strategy to get off the line smoothly from a dead stop, but it isn't hard to do, and takes about a week of driving to get it down perfect.
That said, the truck containing my 12-bolt and 4.11s should be on its way right now. I'm nearly certain that I'll like the aluminum flywheel even more with the taller gears making it even easier to get my little piggy off the line.
Im running a Spec 3 with light flywheel in my swap car. Its DEFINETLY different driving with that set up than a regular set up.
First and foremost, starting off is trickier. The car will stall fast if you arent giving a few more revs than usual. I try to use as little revs as possible...but every so often Ill end up on the verge of stalling.
When driving, the revs will drop fast. When you hit the clutch, the RPMs dive pretty quick. So when you hit the next gear, sometimes you have to give a touch of gas before you let out the clutch. Or else you will get a lurch. Atleast in my experience.
Get over all that, and the fun factor will make you happy. Revs are fast, throttle response is great, and it seem alot more nimble when you are running through the gears.
Ide say if you are mostly cruising around the streets, on the weekends or whatever, go with steel. If you drive it alot, and its mostly spirited driving, then go with the light one. Im pretty sure the steel flywheels are better for drag racing..so how many times you go to the track could sway your decision some.
Justin
Justin
Justin
Justin
My wife's LS1 Trans Am had a SPEC aluminum flywheel, and when it came time to replace the clutch, we found that the previous owner overtightened the flywheel bolts and stripped out some of the threads. At this point, I just said hell with it and bought a used stock flywheel, and to be honest, I really can't tell that much of a difference between it and the aluminum. I think most of the "noticeable" gains are in people's minds...
Originally Posted by PoorMan
Do you resurface the light weight ones just like the stockers or are they trash after once disc?
Aluminum wouldn't be able to handle the heat and pressure by itself (no inserts).
