Automatic Transmission - Shaking when in fourth,please help!!
SPRAYED 01
10-11-2006, 08:12 PM
This just started a couple days ago. If i take off from a stop at a steady 1/8-1/4 throttle when it shifts into 4th it chatters and shakes the car. Then it goes away after about 3 seconds. Any ideas,no other problems, every thing else works perfect. I was at the track saturday and accidently shifted into 4th on the spray once.
performabuilt
10-11-2006, 08:21 PM
Best guess would be some converter clutch chatter ,
SPRAYED 01
10-11-2006, 08:23 PM
How serious would that be. It doesnt really both me that much but at the same time i dont want to damage anything else. Would it be an actually converter problem or some kind of weird tuning issue???
performabuilt
10-11-2006, 08:33 PM
well tuning might hide the problem but more than likley the converter clutch has burned , Eventually it will fail if this is true ,
Vince @ FLT
10-11-2006, 08:35 PM
Tcc problem or a check ball thats stuck in the seperator plate would be my guess.
