Reverse... Fuckin t56's haha
Old 10-11-2006, 09:47 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
Default Reverse... ****** t56's haha
reverse has always worked fine, but today, I drove around for like 2 hours, then parked. I them left after about a hour or so, and I couldn't get it into R. I had to take both hands and force the shifter past the lock out, and then into gear, and it stayed perfectly, no problems. Now I have to do that every time I need to put the car in reverse, wtf is the matter? I also noticed once at a light I couldn't keep the car from rolling forward in gear with the clutch in, without the brake on, but if it was in N with the brake off, it wouldn't roll... As if the clutch wasn't fully disengaging...
Old 10-11-2006, 10:42 PM
wrencher
wrencher's Avatar
Can you put in right into reverse w/out the engine running? If yes,
Sure sounds like you have hydraulic issues there.Specially it moving forward in gear clutch depressed, thats the only thing that can do that all the sudden & cause shifting complaints.
Old 10-11-2006, 11:24 PM
Sgt. Spuds's Avatar
it does it when the cars off too, and the moving forward in gear thing only happend once...
Old 10-11-2006, 11:27 PM
BMW ///M Nerd
BAD ASS TA WS6's Avatar
Try going 1st, then to reverse. You're synchro may be worn, and the 1st to reverse trick is how it's supposed to be done anyhow.
You're main problem is that you're car more than likely needs a clutch/throwout bearing. How many miles are on the clutch? I know the car has high miles, have you done a clutch since you bought it?
Rob
Old 10-11-2006, 11:38 PM
Sgt. Spuds's Avatar
That doesnt work, tried it
I forgot to mention, as it totaly slipped my mind, that everyonce and a while car wont go into reverse without easing up on the clutch and holding up on the lever.
I have no idea how many miles are on the clutch, 145,000 I would belive.
Old 10-12-2006, 07:21 AM
malott442's Avatar
Either your slave cylinder is not disengaging the clutch fully, or your pressure plate is worn out and not disengaging itself. Sorry to say it brother, but you are going to DESTROY your transmission if you try to muscle it into reverse like that. Little secret for R. Shift with the motor off into reverse, and you won't hurt that 1500 dollar potential boat anchor. Remember, unless you love spending money and riding the bus, then treat that t56 gingerly.
Old 10-12-2006, 07:39 AM
Sgt. Spuds's Avatar
It does it with the car off too man, I already stated that.
Does it with the car on
Does it with the car off
Does it even if I shift from 1st to Reverse first with the car on
Does it even if I shift from 1st to Reverse first with the car off
Old 10-12-2006, 08:56 AM
calhoon's Avatar
Check for power to the solenoid as I suspect you have none. That would yeild a full time load as it takes power to release the load.
Old 10-12-2006, 09:08 AM
Sgt. Spuds's Avatar
Were is the solenoid located on the tranny, pictures would help.
Old 10-12-2006, 09:43 AM
Sgt. Spuds's Avatar
ALright, I checked teh fluid, its pretty clear and full...
Also got under the car and looked around and couldn't find anything unplugged. The reverse lockout appears to come off the tranny right up by were the shifter mounts, correct? How can I test my solenoid?
Old 10-12-2006, 09:51 AM
calhoon's Avatar
You can unplug it and power the solenoid directly with 12v. You can test the plug for power with a VOM( key on & key off). It also sounds like you have a clutch release( not fully releasing) problem going on at the same time.
Old 10-12-2006, 09:53 AM
Sgt. Spuds's Avatar
I think I may have just been on crack or something when that clutch disengaugeing problem was going on, as it doesnt do that anymore, just that one time haha..
Old 10-12-2006, 10:04 AM
BMW ///M Nerd
I still say that thing is going to need a clutch. Gaurantee your problems go away.
You can check the lock out solonoid, but if it does actually go in, it's not that. The solonoid wouldn't allow you to get it in. Even if you forced, it wouldn't go.
145k, and you don't know if a clutch has been done?
Needs a clutch...
Calhoon has the right idea to test the lockout solonoid if you want to try it. Go to sears or Radioshack and get yourself a decent dvom/multimeter.
Old 10-12-2006, 10:18 AM
Sgt. Spuds's Avatar
I have a very, very nice fluke multimeter... I just cant see how this could be a clutch problem. My clutch grabs GREAT on hard up shifts, catches power shifts, and I can put the car in sixth gear at 30 mph, floor it, and it wont burn through the clutch...
The reverse lockout system puts 10lb's of pressure against going far enough to the right to get into reverse, unless you cant move 10 lb's, you can force past it, just like my buddy did at the track when he was spraying his ls1/t56 rx7, and missed fifth, and went to push it up again and caught reverse...
Here's a picture of the two connectors that I tested.
The white one has 0 volts at all times, key on or off. The black one, has zero volts key off, and 4.9 when the key is on.
Old 10-12-2006, 10:39 AM
Sgt. Spuds's Avatar
here is a video of the problem. As you can see the resistance is going left to right, not up and down.
Old 10-12-2006, 11:22 AM
WS6GoFast's Avatar
i have the same problem, Ive replaced the master and slave cyl, at least which leaves the clutch for the problem. To get your car into R just turn it off put it in R then turn it back on, its what i have to do
Old 10-12-2006, 11:44 AM
calhoon's Avatar
The picture states the problem very well. The white plug belongs to the skip solenoid. That other plug in the pic is the speed sensor- don't mess with that. You have another solenoid mid-case , the skip solenoid w/ white connector on the solenoid. I suspect it has the black plug in it that you will need to plug into the reverse solenoid to work( black plug/ black connector solenoid - white plug/ white connector solenoid).
Old 10-12-2006, 11:46 AM
Sgt. Spuds's Avatar
The white plug was plugged into that plug pictured at the top of the picture, are you saying that that is in the wrong position?
Old 10-12-2006, 12:03 PM
Sgt. Spuds's Avatar
Alright, I looked and this is the only other plug that I have found on the tranny
it has 12 volts with key on, but the connector appears broken.
Old 10-12-2006, 12:16 PM
Sgt. Spuds's Avatar
I do have a P0500 code as well, which is a VSS code. But my MPH, RPM's, and CC all work perfectly, but could this be telling the car that its going +5 mph at all times, locking in the reverse lockout?
Quick Reply: Reverse... Fuckin t56's haha
