Matching Heads for TSP 228R
Old 10-12-2006, 05:56 AM
BlueGoat06's Avatar
Default Matching Heads for TSP 228R
i wonder what heads should i get to match the cam??
i'll complete the combo with a FAST 90 Intake.i have an LS2 with mods in sig.
Thanks everybody
Old 10-12-2006, 07:19 AM
slow trap's Avatar
i'd stay with a small runner to promote better velocity/tq.something like an afr 205 or the tfs 215.
Old 10-12-2006, 03:01 PM
Zach@Texas-Speed's Avatar
True, a small runner head will work great with that cam...especially with more compression. You might look into the PRC Edlebrock Terminator Series head with the 200cc runner. It will also have a 61cc chamber so you'll get a great bump in compression as well. For 1899.99 assembled with the double springs they are very hard to beat!!!
Let me know if your interested and I"ll get you more info and help out in any way I can!
Zach
Old 10-12-2006, 04:00 PM
slow trap's Avatar
Zach
doh i plumb forgot about the terminator heads.they seem to be a strong performer also and indeed,the 61 cc chambers you will have a nice and high dcr for some great numbers.is your cam a 112 +2 or 112 +0 ?
Old 10-12-2006, 08:05 PM
Phil'sC5vette's Avatar
I have the AFR 205s milled .20 off with my 228R cam..
PRCs are not a bad choice either
Old 10-12-2006, 09:02 PM
99zman's Avatar
what is the diffrence between the 0 and +2 i know its advance but what will either do for you?
Old 10-12-2006, 09:39 PM
BlueGoat06's Avatar
Zach
Very interested, got a part#? link in your website?
i got the PRC dual springs already with the cam, bought the TSP complete package (cam,dual springs,retainers,seals,pushrods,etc,etc) would i need to buy springs again???
Thanks and sorry for the question. learning everyday about cams and what not, now about heads and intakes.
Old 10-12-2006, 09:40 PM
BlueGoat06's Avatar
112+2
Old 10-12-2006, 09:53 PM
BlueGoat06's Avatar
advancing the cam a couple of degrees would give you more low end and midrange, but less power up top. Retarding the cam does the opposite,it pushes the power band up slightly and give you more top end but you would sacrifice some tq down low.
i'm not an expert though.. trust me, i had to pay to have the cam installed..
Old 10-13-2006, 12:43 AM
pdd
pdd's Avatar
changed VE's also
Old 10-13-2006, 01:11 AM
pist0lpete's Avatar
I hope you don't mind my asking but did you install your cam advanced a few degrees? The reason I ask is because the numbers in your sig are a bit low for that combination.
Old 10-13-2006, 09:29 AM
They are on our website:
http://www.texas-speed.com/shop/item...d=667&catid=40
You won't have to buy springs, the heads without springs are 1675.00 plus shipping. The heads work awesome especially with the small runner!
