Can you put your shifter in backwards?
I just installed my clutch and its a bitch to get into reverse but i think i might have installed my shifter in backwards because i have to push it hard to the right and into reverse like realy push it hard. it doesnt make a grinding noise or ne thing goes in and stays untill i pull it out. At first i thought it was because my clutch is new but now i noitce my shifter is farther back than it was before it seems to shift into the other gears fine like this though? so im not sure.
i just want to no if it is physically possible to put the shifter in backwards cause if it is i most likly did. thanks
Yes you can but it would most likely leak and not seal .Also the stick would interfere with the console. You prolly plugged the solenoids in incorrectly. The reverse solenoid has a black plug and the skip shift has a white plug. They will allow you to mis-connect them.
Cool thanks alot and sorry about all the stuff with the bell housing my brother purchased one for me since he messed up the money and knew i was on a time crunch. Ill definilty check those things out.
Originally Posted by LS198Z28
yes you can install the stock hurst shifter backwards and it will seal and not leak i have done it the only way you can tell it the shifter hits the dash in 1 and 3.
When I installed my Pro 5.0, I 1st tried putting it in with the writing that was stamped into the flange, right-side up. It seemed logical to me. No-go. The writing was up-side down when shifter ball slid into the cup in the tranny. Then I noticed that the mounting bolt holes are offset to one side of the mounting plate. There's no way to install a pro 5.0 backwards. Well, there is if you don't care if the shifter ball isn't sitting inside the cup in the tranny.
