particularly umi. whats different between ls1 and lt1? how would you tell which is which? thanks
Revelation Z28
10-12-2006, 05:25 PM
we have better motor mounts ;)
UMI Performance
10-12-2006, 06:00 PM
Hello,
Yes the motor mounts are different... everything else is the same. Please see pictures below for the motor mount differences. Hope that helps!
LS1- http://www.umiperformance.com/images/2320a.jpg
LT1- http://www.umiperformance.com/images/2325a.jpg
so the lt1 is missing one raised mount?
UMI Performance
10-12-2006, 08:54 PM
Yes, on the LT1 one side uses a pedestal like we show that holds the motor mount, on the passenger side the bolts directly to the K-member where the flat plate is, there is then a clamshell that attaches to the motor.
Hope that helps,
Ryan
