A lil help over here... Pics needed
My search is not working and I could use a lil help. We have mounted a pair of twins (T4/T4 this time) in front of the motor up high, cut out the radiator support and moved it back several inches to make room (also added alum 25x19 radiator)...the issue I can seem to beat is getting the cold pipe from the IC to the TB.. there no room to go under the radiator or feed it up from the bottom due to all the hot pipes/gates etc...so it needs to come from the front, and I'd rather not chop into the hood. I have free reighn, just looking for ideas..../ pictures of what some have done that cut or moved the radiator support.
