Want mild street/strip setup
Ok, since my 93' Z is put away for winter and the motor needs overhauled due to burning oil(cause still unknown), I am gauging ideas as to what to do. Looking for a mild street/strip setup. Will be working on this very slowly over the fall/winter/spring. I'm thinking about reconditioning the block back to stock specs and than having some mild port work done with a cam. I'm an A4 and leaning towards a 2400 stall. Will be putting in 3.73's, so that is covered. Might do SFC's, but that all really depends on the final power output. Tranny is already in plan for a rebuild as its about done for. Any suggestions?
Here is my package- Ported 97 aluminum heads, 1.6 alum. roller's, Comp Cams Xtreme Energies hydraulic roller cam size - .230/.236 @.050 .555/.550 overall @ 112* LSA. stock fuel system, stock injectors,retuned computer, aluminum intake elbow, Hooker Supercomp LT's, 3" full exhaust w/ hooker Aerochamber muffler, electric waterpump, 97 rear end w/ 3.42's.
put down 351rwhp 398#ft tq on a dynojet dyno.
still manages about 24-27mpg on interstate depending on how much i've got my foot into it.
hmm, i'm looking into the 350-400hp range. I'll keep your setup in mind. Thanks.
no problem. i dont really have any complaints about my engine.. besides the fact that im powerhungary and now i want to boost it. lol. but its deffinetly a stout setup.
Well, it just has me concerned. All the problems I have had with this car leads me to believe that it wasn't taken care of by the first owner. IT smokes on startup and when you rev it while in park or neutral. I'll give the intake manifold and check and replace gaskets and what not to see if that will cure my problems. I'm still looking to make 350-400 with a stock bottom end. I'll let you know how it goes.
Hey ITS ME lol. But for real you might as well do like your wanting. A refreshed bottom end and mild port with cam and valvetrain upgrade will give you what you want. There is a guy on MFBA with the SN of SCRMNWS6 that added and LE2 combo to his stock bottom end and pulled off a 400rwhp on a set of TT2s that are 17x11. Just go with your original plans. You and I both know that what they are saying about no problems as far as bore or anything even on my 173K motor that we just pulled apart.
