Lt1 Cam Bearings Help Please
Anybody know if there any issues with the front cam bearings on a LT1? I have a very low mile OEM crate motor that has bearing wear on first journal. It is only on the top. Cam and everything else is perfect. I changes all but was just curious if it is common problem????
Thanks and that sounds like a reasonable explanation. It is actually not easy to see as it was only on the say 10 o'clock to maybe 12 o'clock position on the bearing the remainder were perfect.
