Car dies at start up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
Old 10-12-2006, 11:40 PM
forsale2's Avatar
Default Car dies at start up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
I just added a new cap and rotor, and new water pump, i also took off the TB and cleaned it, i put everything back together and now its not running right, starts then dies, inlessi keep the rpms up, if i let off whn the cars not warm it dies, iv checked all the wires, i had my PCM bench tested and read outta my 1994 z28 camaro, and its fine, the data log i have of my car after the tune up so frecking wacky, all attach it along with one i had when my car was running before i added the new parts, im so lost and so is everyone else, iv checked everything, the car ran fine before i added the new parts so whats the deal? it also sounds like crap now too, iv checked and rechecked everything
File Type: zip
File Type: zip
Old 10-13-2006, 01:08 AM
the_merv's Avatar
Check the Donkey Dick and make sure it's on all the way..
Old 10-13-2006, 01:27 AM
forsale2's Avatar
1le
Old 10-13-2006, 01:30 AM
the_merv's Avatar
That's only thing it sounds like, guess not..
Old 10-13-2006, 01:46 AM
forsale2's Avatar
starts then dies inless i keep on the gas
Old 10-13-2006, 01:48 AM
the_merv's Avatar
Could be the Idle Sensor on the Throttle Body, or a Fuel filter maybe..
Old 10-13-2006, 01:56 AM
forsale2's Avatar
i got a video, i can send to you of what its doing your email?
Old 10-13-2006, 02:06 AM
the_merv's Avatar
Photobucket it..
Old 10-14-2006, 10:20 AM
Pimp Daddy's Avatar
check your fuel pressure, my buddies t/a did the same thing. I found that he had a weak fuel pump that was only putting out about 20 or psi, wich was starving the engine for fuel.
Quick Reply: Car dies at start up!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
