gas pedal does not respond! why?
Old 10-12-2006, 11:54 PM
Nickstock98t/a's Avatar
Default gas pedal does not respond! why?
hi my friends a4 2000 ws6 trans am wont accelerate when you tap the pedal slightly, nor will it accelerate when you push on it like a granny. the only time it accelerates is when you push the pedal almost halfway through. why is that? he's only got 17000 miles on it. thanks guys any reply will be appreciated by us.
Old 10-13-2006, 12:33 AM
calongo_SS's Avatar
slack in the throttle cable most likley..
Old 10-13-2006, 01:24 AM
is that what it is? how do we fix that? how much would it cost him? any other possibilities to why its doing that? what caused that? is this normal? thanks
Old 10-13-2006, 08:14 PM
Hello anybody out there? Calongo? help! we need some advice or some sort of "quote" as to why this is happening. He keeps bugging me! Help! thanks you all!!
Old 10-14-2006, 12:03 AM
calongo_SS's Avatar
easiest thing to do to see if it is slack in the cable is:
open the hood and locate the throttle body.
with the engine off, have your buddy slowly start pressing the gas pedal, if the throttle body does not immediatley start opening there is slack in the cable.
Old 10-14-2006, 03:52 AM
BLKWS.6's Avatar
I think that is a mechanic/dealership trip right there, if all the warning lables on teh thing are to be belived...
Old 10-14-2006, 04:18 AM
huh? what warning labels? believed?
Old 10-14-2006, 06:34 AM
BrandonDrecksage's Avatar
is it at all speeds?
Old 10-14-2006, 09:25 PM
all speeds? its an auto
Old 10-18-2006, 08:51 AM
LS1Formulation's Avatar
Speeds = MPH.
Old 10-18-2006, 04:35 PM
Luna's Avatar
Ok, have a friend go in the car with the car off, have the friend push the pedal all the way to the floor. If the throttle stop and the cable bracket don't touch then you have slack in the cable.
It is VERY easy to adjust. On the throttle cable there is a plastic housing with a clip that basically has 3 positions. One position is is all the way down, one is pulled up, and one is completely removed.
Pull the clip up, this allows a spring inside this housing to move, this spring determines the length of you're throttle cable.
Pull the throttle cable back until the bracket and the throttle stop touch. Then snap the clip all the way back down to lock the spring in place. If you have TCS you may have to do it on that cable as well.
Tada! No more throttle cable slack.
Old 10-18-2006, 04:40 PM
XxApollynxX's Avatar
I have a problem with my LS1 gas pedal to since I got it, I can't seem to get it to leave the floor.
Old 10-18-2006, 04:48 PM
g-ryde1's Avatar
^ i believe thats with every LS1 owner.
Old 10-18-2006, 11:04 PM
thanks luna! we'll try thim tomorrow for sure!! hey g ryde and apollynx please be more specific. what do u mean u cant get her to leave the floor and what do u mean thats with every ls1 owner? im a newbie and your statements have gotten me curious. cause im real **** bout my car. thanks dudes
Old 10-18-2006, 11:18 PM
TransAminal's Avatar
It's a joke bud. Hence the smiley faces.
They are joking about the fact that they always floor the throttle because its fun, so its "always stuck to the floor"
Old 10-18-2006, 11:23 PM
blue98Z's Avatar
They mean that these cars are so powerful that our FOOT KEEPS THE PEDAL STUCK TO THE FLOOR!
Old 10-18-2006, 11:42 PM
juicedls1's Avatar
Could also be a bad tps (throttle position sensor) sensor or just buildup in ur trottle body
Old 10-19-2006, 12:18 AM
Revelation Z28's Avatar
+2 for the TPS.
check voltage and resistance on it.
Old 10-19-2006, 07:18 PM
SpaZMaN's Avatar
you might have to explain. not many people know how to do this.
Originally Posted by @nthony
+2 for the TPS.
Old 10-19-2006, 07:55 PM
juicedls1's Avatar
its easiest to hookup a scanner and make sure your tps voltage goes from ovolts to 5volts (full throttle) or 0%-100% with a voltage meter find the signal wire and probe into it and watch the volts as you go from no throttle to full throttle.
