Autometer ultra lite 2's and injector harness
Hey folks,
I'm looking for 3 Autometer Ultra lite guages.
Electrical full sweep Oil pressure w/sender
Electrical full sweep Trans Temp w/sender
Mechanical boost guage full sweep
I also need 8 - LS2 to LS1 injector harnesses as I'm swapping my factory LS2 injectors out for LS1 style 50lb injectors from Speed Inc.
Also need a KB Boost-A-Pump.......
Pm me here please if you have a reasonable offer......
I can swap harness with your if you want. I have a stock LS1 Harness and was going to cut off the ends to solder on pigtails for the newer style injectors, but if the main plug is the same, maybe it is just easier for us to swap harnesses. I can check mine main connector when I get home.
