Ls6 in a 98 gmc 1500
I have a 98 SWB 1500 that has a vortec 305. I came across a good deal on an ls6 picked it up currently rebuilding it. What parts do i need to make it happen and the big kicker is i want to keep FI so where do i get a wiring harness. Will my stock K-member work? Otherwise i guess i am gunna find an s-10 or turd gen.
The easiest thing that you could is check out Street and Performance at www.hotrodlane.cc. They should have the things that you need like computer, harness, motor mounts and the have a good tech department. They have helped me a lot with putting a LS6 and T-56 into a 1956 Chevy truck
MASS seller approved
We have completed this swap in our shop truck. We can provide you with all the correct motor mounts for the swap. Street and Performance at www.hotrodlane.cc sells mounts that will work, but you need to get new driveshafts, cooler lines etc... Our mounts put the the engine and trans in the exact same spot as the original motor. Therefore less things need to be fabricated.
Let me know if you are 2WD or 4WD.
Send us an E-mail or PM we'll help in anyway we can.
Thanks
Thanks
Thanks
Thanks
Real curious what you guys offer, and how you dealt with the low mounted a/c compressor on the OBS trucks.
I'll get some pics up in the next couple of days.
We relocated the a/c up to the passenger side head. We'll be using a completely stock setup off of a 94' 1500. Using the lines, accumulator etc so the only custom part is the bracket to mount it to the LS1 engine.
For the entire swap, the only custom parts are the engine mounts and the wiring harness. Everything else is off the shelf parts from the OBS truck, or new parts from a 99+ 1500. We even used stock manifolds and the stock y-pipe from a new 6.0L truck before we got a set of long tubes on it.
If we had swapped in a dash from a new truck like we originally planned, we wouldn't of even needed to make a wiring harness as it would of all plugged into the harness with the dash from the new truck.
LS1 Installation...
Originally Posted by 350SS
I'm curious as to why you decided to go with the older style a/c compressor. Easier to mount?
Like Tim said we'll get pictures up as soon as we can, pictures will help explain a lot of it.
