Idle help
Idle help
Will not having the AIT wire hooked to the sensor cause idle problems? Also I have longtube headers installed but no cat back. I cant install the O2 sensors until I get it to a exhaust shop. Will not having the O2 sensors connected cause idling problems? I think I have this issue just about nipped but I want to be sure.
Not having the o2's hooked up is gonna cause the motor to run like crap. The PCM needs feedback on how the motor is running. The o2 sensors play a crucial role in this as they provide the PCM with how well your A/F is being burned and where its at. AIT??? Sure you don't mean IAT??? The IAT not being hooked up will throw a SES and it will read "Fuel Lean Monitor". Both of these sensors are crucial to the operation of the engine.
Originally Posted by LT1BRN
i still think its the BBK gone coco.
I was quick to blame the chip because that's what they told me. In the end the chip was installed wrong but it still didnt fix the issue. Now I'm sure it's not the chip. I'm hoping it was all due to the sensors not being plugged in. I didnt notice any vaccum leaks but I'm not ruling it out. We should know for sure tommorow. I'm just glad the car is finally moving on it's own power. I have the worst fvcken luck with cars in the middle east.
you think? I believe you've seen my dyno graph
