View Poll Results: For G5X3 + M6 owners, what gear?
Cam only, stock 3.42 gears
3
13.64%
Heads and Cam, stock 3.42 gears
1
4.55%
Cam only, 3.73 or better gears
6
27.27%
Heads and Cam, 3.73 or better gears
12
54.55%
Voters: 22. You may not vote on this poll
Old 10-14-2006, 11:54 AM
hammertime's Avatar
Default For G5X3 + M6 owners, what gear?
I'm looking at running this cam when the funds are available, however, my current budget will probably allow for a 12-bolt or heads, but not both this winter. Wondering what would be the best order to perform the two. In addition to answering the poll, please feel free to share any other pertinent information (LSA, Whose Heads, if not stock, what ratio, F-body/GTO/Y-body, LS1/LS2/LS6)
Thanks!
Old 10-14-2006, 12:36 PM
ibepressin's Avatar
The g5x3 screams I would do 4:10's with it. Then againg you will be going nowhere fast unless you uprade the rear and add some sticky tires to the combo. If you do heads and cam and skip the rear and stay on street tires you should be ok. If your going heads and cam using the g5x3 fly cutting of the pistons may come into play depending on the ammount of milling on the heads and thickness of your head gaskets. Heads I would go with afr 205's.
Old 10-14-2006, 01:00 PM
N4cer's Avatar
I'm getting ready to switch to this:
G5X3 112LSA
Livernois Stage 2 LS6 heads
Flycutting pistons
ARP2000 rod bolts
I'll begin the rear end savings just after finishing this phase of the build.
Old 10-14-2006, 01:29 PM
TOS98SS's Avatar
Well if I were you I would do the rear and the cam then get the heads later when you have the money . Or you will just be burning up tires
Old 10-14-2006, 02:33 PM
hammertime's Avatar
I've read extensively the G5X3 vs. MS3 poll, and Lou himself answered many questions about the cam. AFR 205's have more clearance after being milled to 59cc's than the stock LS1 heads. On a 114 or 112 LSA, it will clear just fine with .040 cometics head gaskets.
That said, I'd be stupid not to check, but it should clear.
I thought that was half the fun? I'm not planning for this to be a track car, just a fun street driver when I have time to enjoy it. More concerned that it may not be as enjoyable without some 4.10's.
Please keep 'em coming!
Thanks!
Old 10-14-2006, 02:38 PM
spazzyfry123's Avatar
4.11's and nothing less. I use this on my daily driver and I love it. The gas mileage isn't too much worse than it was with the factory gears and it pulls so much harder. With the factory gears, I could burn through first and a little through second. Now with the same tires and only changing out the rear-end gear, I could burn first, second, third, and chirp fourth. I'd say they could make your everyday car "fun".
Old 10-14-2006, 05:09 PM
purdueranger's Avatar
4.33 here but i have the X4.
Old 10-15-2006, 10:49 AM
hammertime's Avatar
TTT - and not sure how I created a pole and a thread at the same time
Old 10-15-2006, 12:54 PM
N4cer's Avatar
What do you mean? That's how it works.
My vote: G5X3 on a 112, flycut (rent the tool), stock heads, 12-bolt. Then save for heads later. The heads will depend upon your budget. I basically decided on Livernois heads because although I had the money saved to buy ETP, TEA, AFR, etc., the "best" heads, the numbers just don't show that much of a difference for me since I don't win any money racing. And the 215cc runners of the Livernois heads was another big selling point for me since the other companies are running huge runners. Yeah, good flow numbers. So what does that mean when I'm losing torque down low because of some huge runners on the more popular heads?
Old 10-15-2006, 02:37 PM
hammertime's Avatar
I've never noticed a thread separate from the poll...
https://ls1tech.com/forums/generation-iii-internal-engine/591981-g5x3-m6-owners-what-gear.html
As far as heads, I'm pretty firm on AFR 205's for the high flow and velocity of the stock size intake runners. If I decide to do the rear first and not heads, and need to flycut to run the cam with my stock heads, I may as well get it ground on a 110 LSA for a little more midrange punch.
Old 10-15-2006, 08:06 PM
cws T/A's Avatar
Louis at LGMotorsports stated that no piston notches are needed running stock heads / AFR 205cc 59cc with .040 cometic head gaskets .
4.10 - 4.30 - 4.56 depending on tire height
Old 10-15-2006, 08:18 PM
spy2520's Avatar
HumpinSS runs 4.56s on a 28" tire i think...
Old 10-16-2006, 11:55 PM
hammertime's Avatar
back ttt
Old 10-17-2006, 12:09 AM
chris.shea's Avatar
How hard would it be to drive on a 3.42? just ride the clutch past 1,500 rpms?
Old 10-17-2006, 12:30 AM
cws T/A's Avatar
I dont think it would be that bad this cam produces power down low to .
Old 10-17-2006, 01:03 AM
chris.shea's Avatar
cool, would it work for a 402 also?
Old 10-22-2006, 09:31 PM
hammertime's Avatar
ttt
Only 14 votes? I know there are more than that running this cam...
Old 10-23-2006, 12:46 AM
OneMeanZ's Avatar
Personally, if it's your DD or you drive it a lot. Go 4.10s, if not, go 4.30s
Old 10-23-2006, 10:04 AM
yak
yak's Avatar
4.33's and a 28" tire
Old 10-23-2006, 10:12 AM
black_z's Avatar
4.30's
Quick Reply: For G5X3 + M6 owners, what gear?
