Anybody have this problem with Lokar tranny dipstick?
Old 10-14-2006, 08:16 PM
SilverBullet73's Avatar
Default Anybody have this problem with Lokar tranny dipstick?
Ok. So I was using my original 4l60e tranny dipstick for an LT1 and the tube assembly cracked my heater box(grrrr). I didn't like how it looked so I bought a Lokar 24" firewall mount. So I try to insert the fitting into the just rebuilt Rossler trans and it won't fully seat! What the hell? I would guess that the dipstick would have to seat passed the second o-ring so it would read correctly, no? I can only get it in just before the second o-ring. I put silicone on it, oil and it wont go in any further. Should it seat completely? If so, then I might have to hit it with an some fine grit sand paper. Someone please let me know. Thanks in advance.
Old 10-14-2006, 09:48 PM
Stu Cool's Avatar
Not putting you off, but my first call would be to Lokar to get their advice.
Pat
Old 10-14-2006, 10:18 PM
screamin seeman's Avatar
I machined .050 off the taperd side of the nut. My dipstick was for a 700r4, but I put it in a 4l60e. The dipstick does need to seat completely.
Old 10-15-2006, 09:43 AM
under pressure's Avatar
I just bought a 24" Lokar trans dipstick for my 2004R and the bottom part of the dipstick housing will not even begin to fit the hole in the transmission. I wonder if it is mispackaged maybe. It is going back. . .
Old 10-15-2006, 01:04 PM
strokedls1's Avatar
I have one for a 4l80e and it fits really tight. I thought it was wrong as well, but I did get mine to seat all the way. I would give them a call also if it will not seat all the way.
Old 10-15-2006, 01:22 PM
Seems like there is a common problem with them in some cases. I'll see what I'll do, thanks for the replies guys.
Old 10-15-2006, 01:32 PM
LS1GMCTruck's Avatar
Default Yup...
I had to wrestle with mine also, but it eventually went down all the way. I applied a small amount of clear silicone sealant, as you did, near the top. They definitely don't go down in the hole easy. Gar
Old 10-15-2006, 01:36 PM
Lightbulb That reminds me...
I have a "like new" stock factory F-body dipstick & guide tube available, if anyone wants to make me a fair offer. It came off my 2001 LS1 that only had 3,000 miles on it. Thanks, Gar
Old 10-15-2006, 03:21 PM
jagwrjack's Avatar
My lokar broke inside the block and I had to jury rig the leftover tube with
silicone. Really pissed me off because I could have gotten by with the stock
dipstick tube but just had to get fancy with the Lokar.
The broken end is now floating around in the pan.
I heard that some of their dipstick tubes were machined wrong and you can get an exchange one.
Might have read that on torquecentral
Old 10-15-2006, 04:41 PM
Stu Cool's Avatar
For anyone who is interested in a stock application that is not as long as the FBody, I picked up a fill tube and dipstick here:
http://www.bulkpart.com/Merchant2/me...=&Store_Code=2
Fit's perfect and works great. Only $16 plus shipping. Here are a couple pictures of it installed
Pat
Quick Reply: Anybody have this problem with Lokar tranny dipstick?
