z06 intake, heads, and cam swap into ls1
Old 10-15-2006, 10:54 AM
slickz28's Avatar
Default z06 intake, heads, and cam swap into ls1
Wondering if anybody has done the swap and if there was much power difference. I own a 98 trans am, and will be adding ls6 heads, cam , intake out of my body's 2002 z06.
Old 10-15-2006, 10:56 AM
michael402z06's Avatar
you will get a big power increase with the heads and intake mainifold, but if i were you i would go with a bigger cam since you will have the cam out anyway.
Louie83's Avatar
The LS6 intake is good, but if I went H/c, personally I'd go for the 90/90 since it makes a huge gain over the LS6 intake with any aftermarket H/C set-up.
As for the LS6 H/C, there are much better out there. But since you are getting them from a buddy then it is probably an unbeatable price.
Old 10-15-2006, 11:30 AM
there aren't huge gains from a ls6 to a fast 90 with a stock cubed motor. maybe a few hp. there are a lot of threads on this.
Old 10-15-2006, 02:29 PM
HILL_SS's Avatar
I agree with michaelsvt03, install the intake and the heads and find a little more aggressive cam and you would see a pretty solid HP/TQ gain!
Good Luck!
Old 10-15-2006, 04:06 PM
Louie83's Avatar
That is incorrect.
Read the results of this testing done by Brian Tooley.
https://ls1tech.com/forums/generation-iii-internal-engine/528602-massive-dyno-testing-session-revealed.html
I read the dyno section all of the time, and H/C 346's pick up 15-25 with 90/90 over LS6 and ported TB consistently.
Old 10-15-2006, 07:28 PM
Camaross124's Avatar
the only way fast 90/90 is worth it is if you are going with some bomb *** ported heads... anything else the choke point is the heads not the LS6 intake...
i do agree though that the ls6 intake is the choke point for a good set of ported heads
Old 10-15-2006, 07:48 PM
Camaro Rick's Avatar
I'm doing almost the same thing. In a few days I can let you know how the ls6 intake and heads work with a 220/220 cam. I was considering doing the same as you but figured I'd go bigger anyway while it's all apart. I had the intake already and noticed a nice gain. I'm also adding some longtubes into the rebuild. So we'll see how it goes.
Old 10-16-2006, 07:24 PM
slickz28's Avatar
Thanks, let me know how it turns out camaro rick!
