Generation IV Internal Engine - ls1 coil packs on an ls2
Black93Z28
10-15-2006, 10:57 AM
Is there a way to use ls1 coil packs on an ls2? the ls2 is center bolt valve covers and the ls1 is perimiter so its not as simple as switching them. does anyone make a conversion bracket because the ls2 coil packs are in the way of my ls1 fuel rail.
Gregory
10-15-2006, 11:25 AM
Be careful . . . I called MSD about the coil packs for the LS2 and they said the coils are not available yet. They have a different part number. I was also told the electrical connection is different.
HSV-GTS-300
10-15-2006, 05:42 PM
Weird.
I run LS1 coil packs on my LS2. The coils and valve covers came from an 01 LS1 and were no trouble at all to fit to an 05 LS2.
The 2 main (coil group) electrical connectors are not different, but the 8 tiny connectors to each individual coil are different. The LS2 plug leads are L shaped and fit better.
http://i2.photobucket.com/albums/y20/PerthPurplePenguin/car%20parts/044.jpg
http://i2.photobucket.com/albums/y20/PerthPurplePenguin/car%20parts/P2020129.jpg
LS2.
http://i2.photobucket.com/albums/y20/PerthPurplePenguin/P1010127.jpg
LS1.
http://i2.photobucket.com/albums/y20/PerthPurplePenguin/P1010128.jpg
Note: LS2 coils are much "taller" and will hit on some LS1 fuel rails.
blown402
10-16-2006, 08:47 AM
I used my valve covers and coil packs on my ls2, thay fit just fine. this is all in my '99 camaro.
Black93Z28
10-16-2006, 09:44 AM
i dont know how since like i said the ls2 is center bolt and my ls1 is perimiter. unless you guys are unbolting the coil packs themselves from the valve covers and using those? will the brackets be the same?
Black93Z28
10-16-2006, 10:50 AM
Well the LS1 coil packs bolt directly to the valve cover. and the ls2 bolts to a bracket.
heres a pic of the ls1 Valve covers/and coil packs.
http://i59.photobucket.com/albums/g304/TPIMarow6point6/HPIM0677.jpg
pic of the ls2 valve covers and coil packs.
http://i59.photobucket.com/albums/g304/TPIMarow6point6/HPIM0676.jpg
code4
10-16-2006, 11:15 AM
You can order 2 center bolt coil brackets. They are under $9 each. Part number 12563288. Your 98 coils are the same as later models & will bolt to the newer bracket. I used a 98 harness engine harness to match the harness on the bracket. If you are going to use a newer engine harness I would get a new bracket harness or reconfigure the pins. Hope this makes sense to you.
Black93Z28
10-16-2006, 11:23 AM
Yeah i think im going to reposition the bracket down an inch or so. so itll be enough to clear and the covers will still go on.
jgonzales
10-16-2006, 05:28 PM
Valve covers on '99 and up LS1's were all center bolt right? So yours must be a '98? Like he said before, I think the coils are the same, just mounted differently. So just get the different mounting brackets and that should fix the problem.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
