What Pistons for Eagle 383 Stroker Kit???
Old 10-15-2006, 11:07 AM
gman66's Avatar
Default What Pistons for Eagle 383 Stroker Kit???
What Pistons should i pick for my Eagle 383 Stroker Kit i am purchasing for my street car prodject? I will bw running So. Cal. 91 octane swill. My choises from eagle are as listed on there order sheet below. I will be using 62cc chamber Trick Flow Heads which will get me at apr. 11.4 to 1 which may be a little to much for the 91 octane. My other choice is to go with the KB dished pictons and mill the heads down to the compression i require.Anybody have any experience with this???.........Thanks Gman
Eagle ESP Cast/Steel 3.750" Stroke Crankshaft (Internal Balance) 1 piece rear seal part # 10352375057i
5.7" 5140 steel SIR (Full float bushed) rods with ARP bolts (SIR5700BBLW), these rods are clearanced for up to a 600 lift cam!
Keith BLACK KB135 DISH PISTONS .030, 040, .060 pistons 10.4:1 comp w/58cc head, or 9.8:1 with a 64 cc head, 8.7:1 with a 76cc head. (Compression also dependent on your deck height, advertised compression is at ZERO deck) If your deck hight is higher your compression will be slightly lower.
Keith BLACK KB134 FLAT TOP PISTONS .030, 040, .060 pistons 11.8:1 comp w/58cc head, or 11:1 with a 64cc head.
Old 10-15-2006, 11:47 AM
streetwarrior96's Avatar
JE/SRP Flat tops
You should get the forged steel crank, Eagle, Callies, Lunati
Quick Reply: What Pistons for Eagle 383 Stroker Kit???
