Budget heads
Old 10-15-2006, 02:12 PM
DustinWS6's Avatar
Default Budget heads
I want to throw some heads on my, but I'm an almost broke college student. What are some heads that are relatively inexpensive that will flow well on my set-up? Thanks
Old 10-15-2006, 02:18 PM
eric01ss's Avatar
tsp prc stag 1 heads check out texas speed and performance ->
Old 10-15-2006, 02:20 PM
DustinWS6's Avatar
Will do. Thanks
Any other opinions?
Old 10-15-2006, 02:27 PM
Moderator
davered00ss's Avatar
Patriot Performance had CNC'd LS6 Heads for $995.
Old 10-15-2006, 02:28 PM
BLAKE 01 WS6's Avatar
+1 also a real 243 ls6 head, not ls6 "style"
look in the dyno section, 518 rwhp with these heads on the stock botom end!!!
Old 10-15-2006, 02:31 PM
rocketman442's Avatar
Look for some used heads, I bought GTP heads for a screaming deal.
Old 10-15-2006, 03:08 PM
DustinWS6's Avatar
http://www.texas-speed.com/shop/item...d=680&catid=47
Is this the prc stage 1 head? For some reason it only comes up in the heads/cam package section
Old 10-15-2006, 03:14 PM
eric01ss's Avatar
no just go to cylinder head section u will see them they are like less then a grand should be on there main page!!
Old 10-15-2006, 03:22 PM
Moderator
That less than a grand is with the stock Z06 springs. You will need better springs if you are running a cam larger than the ls6 cam.
Old 10-15-2006, 03:28 PM
4yall2nv's Avatar
this is the website, http://www.texas-speed.com/shop/item...d=649&catid=20
Old 10-15-2006, 04:26 PM
Chris Gage's Avatar
PRC's seem to be the nicest budget head out at the moment, but you can always get great deal on used heads that are superior to PRC's.... just research and look around. Dont jump into anthing to quick. Make sure your heads will go perfectly with the near future mods you plan to do!
Old 10-15-2006, 04:38 PM
Mssingkid's Avatar
Ls1Joe Just made 518rwhp with some TSP Stage 1 heads... not to shabby i'd say...
Old 10-15-2006, 04:57 PM
Moderator
Personally I don't like the hogged out intake runners on the PRC heads. Seems like you would loose a lot of low and midrange to get the top end #'s.
Old 10-15-2006, 05:12 PM
TVWilkes's Avatar
There is no heads in this price range ( used or new) superior to the PRC heads.The PRC LS6 heads are the finest LS6 head ever produced.The results speak for themselves.The flow numbers are very stong thru the entire range from .100 up to .600.IMO, the PRC line of heads are the best you can buy.The have top notch equipment and manufacturing. The R&D from them is always going 24/7.
Old 10-15-2006, 05:21 PM
Chris Gage's Avatar
Originally Posted by Terry@RacetechSpeed
There is no heads in this rice range ( used or new) superior to the PRC heads.The PRC LS6 heads are the finest LS6 head ever produced.The results speak for themselves.The flow numbers are very stong thru the entire range from .100 up to .600.IMO, the PRC line of heads are the best you can buy.The have top notch equipment and manufacturing. The R&D from them is always going 24/7.
I take it I was qouted because of saying you can find great deal on superior heads. With that statement, I was talking about aftermarket castings such as AFR's, ect. GTP seems to be a pretty nice head. No, you cant beat the bang for the buck that PRC heads offer, but you can up performance a bit buy going with something like TFS, AFR, ETP, ect......
While looking at the option taht are out for this member, Stage 1 PRC heads will be the best option.
Old 10-15-2006, 05:23 PM
Moderator
I would love to see someone take 1 car Dyno before, then try out PRC's, Patriots & AFR's to see how they really comopare.
Old 10-15-2006, 05:42 PM
Chris Gage's Avatar
AFR's are in a different category then Patriot and PRC's... AFR's are an aftermarket casting while Patriot uses LQ4 heads and PRC uses LS6 heads
Old 10-15-2006, 05:55 PM
Moderator
Yeah, but they do claim similar #'s.
Old 10-15-2006, 05:57 PM
Chris Gage's Avatar
Intersting point, have you tried serching for similiar combo's that both set of heads have been dyno'd on?
Old 10-15-2006, 05:58 PM
TVWilkes's Avatar
Just because they have an aftermarket casting doesn't automatically up the performance.The only one that may out perform the PRC heads would be the TFS,from the info and stuff that I here,but that remains to be seen.I know how much time they spend in the R&D department.The results from them will continue to get better and better.
