General Maintenance & Repairs - Valve Chatter?
98_z28
10-15-2006, 02:52 PM
is it normal that every time i pull out in first my valves chatter ? It only does it when i pull out in first then as soon as the rmps get to about 2000 it stops it does it just about every time
Brandon35thSS
10-16-2006, 12:58 PM
what octane gas do you run? if you run 87 try stepping up and using premium and then see if it stops. if youve been using premium get it from a different station next time. my car hates 87 octane.
staringback05
10-16-2006, 02:51 PM
yea that deff. sounds like either carbon build up or...bad gas....clean your fuel system
98_z28
10-17-2006, 09:00 AM
I use shell v-power just about every time when i first got my car about a month ago i used 87 but now i use 93 every time would some fuel treatment help
Brandon35thSS
10-17-2006, 12:06 PM
try getting gas at a different station and see if it helps. it might just be some bad gas in there tanks
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
