LS1 connector identification
Old 10-15-2006, 09:02 PM
heimbo's Avatar
Default LS1 connector identification
I had some time the other night so I started going through my harness and labeling what plugs to what (with some help from a friend), I have most of it figured out except for a few plugs. I'm doing this without the motor since it is not here at school with me. So Need to ID these last few to make things easy.
2 of these, Knock or cam sensor?
Greens are usually diagnostic? however I'm not sure on this one.
Skip shift adapter with resistor?
All these are from a 98 M6 harness.
Thanks any help is appreciated, it is all still in tact from the pullout and I haven't started to clean it up just yet.
Dave
Old 10-16-2006, 03:24 PM
heimbo's Avatar
any ideas?
Old 10-16-2006, 03:30 PM
stealth71's Avatar
wire colors associated w/ them usually help
Old 10-16-2006, 06:04 PM
heimbo's Avatar
Green connector- yellow and black wire
Yellow weather protector-black, blue, green.
Old 10-16-2006, 06:48 PM
Brains's Avatar
First pic looks like the TPS and coolant temp plugs. You'll know for sure if one is right by injector #1's connector, and the other is by the idle air plug. Second one (big green connector) is the oil pressure sender. Third is the skip shift.
Old 10-16-2006, 08:07 PM
heimbo's Avatar
Great info, I had the other yellow banded one labeled TPS and wasn't sure about this one.
Do you suggest I leave all the emissions stuff in the harness and just delete them on the PCM side of things?
Old 10-17-2006, 08:22 AM
Brains's Avatar
Yeah, no sense in cutting up the harness unless you're going for ultra pretty
Old 10-17-2006, 09:22 AM
LS1Cobra's Avatar
Everything you need is here. GL. Vinh
Engine Controls Connector End Views
Table 1: A/C Compressor Clutch
Table 2: A/C Refrigerant Pressure Sensor
Table 3: Camshaft Position (CMP) Sensor
Table 4: Crankshaft Position (CKP) Sensor
Table 5: Engine Coolant Temperature Sensor
Table 6: Engine Oil Level Switch
Table 7: Evaporative Emission (EVAP) Canister Purge Valve
Table 8: Evaporative Emission (EVAP) Canister Vent Valve
Table 9: Exhaust Gas Recirculation (EGR) Valve
Table 10: Fuel Injector #1
Table 11: Fuel Injector #3
Table 12: Fuel Injector #5
Table 13: Fuel Injector #7
Table 14: Fuel Injector #2
Table 15: Fuel Injector #4
Table 16: Fuel Injector #6
Table 17: Fuel Injector #8
Table 18: Fuel Tank Pressure Sensor
Table 19: Heated Oxygen Sensor (HO2S), Left Rear
Table 20: Heated Oxygen Sensor (HO2S), Right Front
Table 21: Heated Oxygen Sensor (HO2S), Right Rear
Table 22: Idle Air Control (IAC) Valve
Table 23: Intake Air Temperature (IAT) Sensor
Table 24: Knock Sensors (KS)
Table 25: Manifold Absolute Pressure (MAP) Sensor
Table 26: Mass Air Flow (MAF) Sensor
Table 27: Reverse Inhibit Solenoid
Table 28: Secondary Air Injection (AIR) Bleed Valve Solenoid
Table 29: Secondary Air Injection (AIR) Pump
Table 30: Skip Shift Solenoid
Table 31: Throttle Position (TP) Sensor
Table 32: Vehicle Speed Sensor (VSS)
Connector Part Information
1216-2017
2 Way F Metri-Pack 150 Series (GRY)
A
DK GRN
59
A/C Compressor Clutch Control
B
BLK
450
A/C Compressor Clutch Ground
1211-0192
3 Way M Metri-Pack 150 Series Pull To Seat (BLK)
A
BLK
407
A/C Refrigerant Pressure Sensor Ground
B
GRY
474
A/C Refrigerant Pressure Sensor 5.0V Reference
C
RED/BLK
380
A/C Refrigerant Pressure Sensor Signal
1205-9595
3 Way F Metri-Pack 150 Series (BLK)
A
BRN/WHT
633
Camshaft Position (CMP) Sensor Signal - Input
B
PNK/BLK
632
Reference Low
C
RED
631
Ignition Feed
1205-9595
3 Way Metri-Pack 150 Series (BLK)
A
YEL
573
Crankshaft Position (CKP) Sensor Signal - Input
B
YEL/BLK
1868
Reference Low
C
LT GRN
1867
Ignition Feed
1211-0192
3 Way F Metri-Pack 150 Series Pull to Seat (BLK)
A
BRN
718
Engine Coolant Tenperature (ECT) Sensor Ground
B
YEL
410
Engine Coolant Temperature (ECT) Sensor Signal
C
DK GRN
135
Engine Coolant Temperature (ECT) Sensor Output
1205-2641
2 Way F Metri-Pack 150 Series Sealed
A
BRN
1174
Oil Level Switch Signal
B
BLK
450
Ground
1205-2643
2 Way Metri-Pack 150 Series Sealed (RED)
A
PNK
239
Ignition Feed
B
DK GRN/WHT
428
EVAP Canister Purge Valve Control
1205-2643
2 Way F Metri-Pack 150 Series Sealed (RED)
A
PNK
239
Ignition Feed
B
WHT
1310
EVAP Canister Vent Valve Control
1218-6056
5 Way F Metri-Pack 150.2 Series Pull to Seat (BLK)
A
GRY
435
Exhaust Gas Recirculation (EGR) Valve Ground
B
BLK
552
Exhaust Gas Recirculation (EGR) Sensor Ground
C
BRN
1456
Exhaust Gas Recirculation (EGR) Pintle Position
D
GRY
705
Exhaust Gas Recirculation (EGR) 5V Reference
E
LT BLU
697
Exhaust Gas Recirculation (EGR) Valve Control
1205-9595
Pin
Wire Color
Circuit No.
Function
A
ORN/BLK
469
Fuel Sensor Ground
B
DK GRN
890
Fuel Tank Pressure Signal
C
GRY/BLK
416
5V Sensor Feed
1216-0825
4 Way Metri-Pack 150 Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
TAN/WHT
1669
LR Heated Oxygen Sensor (HO2S) - Low
B
PPL/WHT
1668
LR Heated Oxygen Sensor (HO2S) - High
C
BLK
450
Ground
D
PNK
539
Ignition Feed
121-60825
4 Way M Metri-Pack 150 Series Sealed(BLK)
Pin
Wire Color
Circuit No.
Function
A
TAN
1667
B
PPL
1666
C
BLK
450
Ground
D
PNK
539
Ignition Feed
1216-0825
4 Way M Metri-Pack 150 Series Series (BLK)
Pin
Wire Color
Circuit No.
Function
A
TAN
1671
RR Heated Oxygen Sensor (HO2S) - Low
B
PPL
1670
RR Heated Oxygen Sensor (HO2S) - High
C
BLK
450
Ground
D
PNK
539
Ignition Feed
1216-2190
4 Way F Metri-Pack 150.2 Series Pull to Seat (BLK)
Pin
Wire Color
Circuit No.
Function
A
LT GRN/BLK
444
Idle Air Control (IAC) Valve Coil B Signal - Low
B
LT GRN WHT
1749
Idle Air Control (IAC) Valve Coil B Signal - High
C
LT BLU/BLK
1748
Idle Air Control (IAC) Valve Coil A Signal - Low
D
LT BLU/WHT
1747
Idle Air Control (IAC) Valve Coil A Signal - High
1216-2199
2 Way F Metri Pack 150.2 Series Pull to Seat (GRY)
Pin
Wire Color
Circuit No.
Function
A
PPL
719
Intake Air Temperature (IAT) Sensor Ground
B
TAN
472
Intake Air Temperature (IAT) Sensor Signal
Knock Sensors (KS)
1205-2641
2 Way F Metri-Pack 150 Series Sealed (BLK)
Pin
Wire Color
Circuit No.
Function
A
DK BLU
496
Knock Sensor (KS) Signal - Front
B
LT BLU
1876
Knock Sensor (KS) Signal - Rear
1212-9946
3 Way F Metri Pack 150 Series (GRY)
Pin
Wire Color
Circuit No.
Function
A
ORN/BLK
469
Manifold Absolute Pressure (MAP) Sensor Ground
B
LT GRN
432
Manifold Absolute Pressure (MAP) Sensor Signal
C
GRY
416
Manifold Absolute Pressure (MAP) Sensor 5.0V Reference
1205-9595
Pin
Wire Color
Circuit No.
Function
A
YEL
492
Mass Air Flow (MAF) Sensor Signal
B
BLK/WHT
451
Ground
C
PNK
539
Ignition Feed
1205-2646
2 Way F Metri-Pack 150 Series Sealed (WHT)
Pin
Wire Color
Circuit No.
Function
A
LT GRN
1652
Reverse Inhibit Solenoid Control
B
PNK
539
Ignition Feed
1205-2643
Pin
Wire Color
Circuit No.
Function
A
PNK/BLK
429
Secondary Air Injection Bleed Valve Solenoid - Feed
B
BLK
150
Ground
1211-0293
Pin
Wire Color
Circuit No.
Function
A
RED
78
Secondary Air Injection Pump Motor - Feed
B
PNK/BLK
429
Secondary Air Injection Solenoid - Feed
C
BLK
150
Ground
Skip Shift Solenoid
1205-2643
Pin
Wire Color
Circuit No.
Function
A
GRY
587
Skip Shift Solenoid Control
B
PNK
539
Ignition Feed
1211-0192
3 Way F Metri-Pack 150 Series Pull To Seat (BLK)
Pin
Wire Color
Circuit No.
Function
A
GRY
596
Throttle Position (TP) Sensor 5V Reference
B
BLK
452
Sensor Ground
C
DK BLU
417
Throttle Position Sensor Signal
1216-2195
2 Way F Metri-Pack 150.2 Series Pull to Seat (BLK)
Pin
Wire Color
Circuit No.
Function
A
PPL
401
Vehicle Speed Sensor (VSS) Signal - Low
B
YEL
400
Vehicle Speed Sensor (VSS) Signal - High
Document ID# 229162
1998 Chevrolet/Geo Camaro
Old 10-17-2006, 06:57 PM
heimbo's Avatar
Thanks LS1Cobra, that's a bit more detailed then the diagrams and write up's I have found online.
Old 10-20-2006, 07:41 PM
LS1-IROC's Avatar
Good info LS1Cobra! Thanks for posting it up.
Quick Reply: LS1 connector identification
