Best Header Gasket for LT1
Tired of replacing these gaskets. I installed Split-Lock fasteners and their still blowing out. Whats the best gasket to use? Brand and part number please.
Originally Posted by Ray@Nitrous Outlet
if you are having that much trouble with the gaskets blowing, check the flanges and head surface to make sure you are getting a good seal.
Also check the header bolts shortly often to make sure they are all tight and that they stay tight.
Originally Posted by 94z28L
i used mr. gasket ultraseals with my pacesetter longtubes, used these after the copperseals blew out been golden since
I only have a few hundred miles on them but sofar Earl's Pressure master are the best I have tried.
Far as not checking because you have good bolts, well it is not the bolts that loosen the gaskets compress first which can lead to bolts loosning but the bolt loosening is a symtom not a cause.
Originally Posted by asudecat
Percy's deal soft aluminum gasket from autozone. That's the best gasket as far as I know
