timing dots
timing dots
Hi guys, cant really find any photos. so ill post this up and ask away.
Im macca33 friend doing a cam C/O fir the first time on my car (using your tech guides) one think im stick on. is i have a double row timign chain. and im not sure if ive got the right dot. on the crank at the back of the journel (near the seal) is a slight inidcation of a dot i cant seem to get a good photo of it.
can anyone show me a photo or correct me... or would easieset way be to do the screwdriver test on #1 ?
That's not a double roller timing set though. The double has a couple dots on it. Here are the instructions for setting the timing: http://www.romac.com.au/pdf/Std%20&%...ank%20Info.pdf .
FYI, you're going to use Box #1 and use the right-most dot on the crank sprocket for standard timing.
