Stereo & Electronics - radio control steering wheel in a 98...
98hardtopZ
10-16-2006, 05:18 PM
i have a 98 and i bought a 01 steering wheel off a camaro with the radiocontrols. i went to plug up airbag and theres no harness coming off airbag? so what do i do for that. and also i realize there isnt radio control wires running through the column but how do you get those to work too? thanks..
regblkss
10-16-2006, 09:44 PM
ok idid this to you need the coil off a 01and a small harness i got from gm it plugs into thecoil and run a wire from the coil to the back of the radio its pin 14 in the white con its just one wire and the wheel puts out diff volts for each button and thats it. also you need a pin from gm to put in the back of the radio.
98hardtopZ
10-16-2006, 10:22 PM
how much? did you just go to gm dealership?
01WS6/tamu
10-17-2006, 08:57 AM
You have to replace the airbag clockspring assembly. It is the same from 95-02. The car I think is already prewired the connector is tucked back to the best of my knowledge. If not all there is is 12v ign grd illumination, signal to radio head.
01WS6/tamu
THe clockspring is about 180.00$
98hardtopZ
10-17-2006, 10:11 AM
why do i have to replace it if its tucked back?
regblkss
10-17-2006, 11:52 AM
i didnt see it tucked away
99blue-Z
02-02-2007, 09:57 AM
I hate to resurrect an old thread, but, From what I gather, all that is needed for this conversion is the clockspring assembly and then, one wire needs to be run to the radio, while the other goes to the ill. circuit to light em up. What coil is mentioned above? Any thing else needed for this conversion. I have a 99 and I can't find any "tucked away" wires, thanks for looking.
Injected1
04-28-2009, 01:52 PM
I want this same question answered.
Ben
