pinging noise when not warmed up
Old 10-16-2006, 09:22 PM
nomoneyz's Avatar
Default pinging noise when not warmed up
hey guys\girls this problem has been going on for a while now and its getting on my nerves latley. When I first start my car and the motor is still cold it makes a pinging sound when i start driving. The sound starts at about 2300 RPMs and up. It doesnt stop until the car is warmed up but its gotten louder over the past month or so. Any ideas would be great.
Thanks
Jeremy
Old 10-16-2006, 09:28 PM
Formula350's Avatar
Spark too advanced for when it's cold and in open loop (open right guys? I get them backwards alot) and when it's warm and switches the computer can compensate for the timing and thus no more ping... So... um spark control, optispark?
Old 10-16-2006, 09:47 PM
nomoneyz's Avatar
how would i check that. I cant stand driving around in the morning. Will it hurt my motor any. Thanks
Jeremy
Old 10-16-2006, 10:13 PM
Formula350's Avatar
Throw it on a scanner and have it monitor the timing while it's running. It won't hurt it per-se unless you are really thrashing on it. Mine does it too but due to bad O2 sensor and close to WOT.
Old 10-16-2006, 10:29 PM
nomoneyz's Avatar
Sorry im still a little new to this. Where do I go to hook it up to a scanner. If thats the problem is it an easy fix. Thanks
Jeremy
Old 10-16-2006, 10:44 PM
Formula350's Avatar
A shop, they may or may not charge you, buy one ($300+) or around here the local parts stores rent them out. Autozone and Checker/Shucks/Kragen.
Seeing as you don't quite know what's going on, I might recommend taking it to a shop then. That's totally up to you though.
Old 10-16-2006, 10:52 PM
nomoneyz's Avatar
Thanks, i'll call my mechanic tomarrow and see what he can do. Man i love this site. Thanks again
Jeremy
Old 10-16-2006, 10:56 PM
the_merv's Avatar
Is it a ping, or a pop..
Old 10-16-2006, 11:05 PM
nomoneyz's Avatar
its deffinatley not a pop and it seems like its from the drivers side. It sounds like i wanna say something knocking but i dont know.
Old 10-16-2006, 11:20 PM
Bad Trader (Louis H)
99S351's Avatar
Im having the same problem only in closed loop! If It sounds like a can full of marbles ratttling on the driverside bank its detonation. I just cant figure out whats causing me to detontate!
Old 10-16-2006, 11:21 PM
the_merv's Avatar
If you are detonating, try running higher fuel. Get it richened, or your timing might be off.
Quick Reply: pinging noise when not warmed up
