what Rad. are you guys using?
7 Second Club
im looking at on this one at summit racing http://store.summitracing.com/partde...5&autoview=sku
its a 27.5 X 15.5 and 3'' thick overall lengths.
right now my car idles at 210.... so after seeing Na$ty TA's car im going to setup my rad. like him and then ill have enough room to put the stock fans back on... .and still have a lot of room behind them for the d1sc.... and a f1c a year or two from now
Sorry i didnt get back to ya... kinda hecktic....
Yes that is the same one i have have.....
But i am not running a stock fan...... i am running a single 16" Spal fan rated at 2800 cfm and the car cruises at or below 185....
The last couple of days its been below 185 with the cool weather....
The day i got stuck in traffic for 2 hrs she never got over 200.
Let me know if ya need any pic's.
Kyle
Kyle
Kyle we need pics, I am wanting to cut the support on my LT1 car for my charger setup (not needed really, but I think it will may more room)
My car is a Street car, so I need it to stay cool.
2000slpss looks good, let me ask you this, when you cut the support does the car want to flex or move??? I suppose you cut it while the car was sitting on the wheels instead of in the air???
Any tips, and did you use a Bi-metal saw? Looks good
Purevil I know has used his stock rad and fan setup and make over 800RWHP, I am thinking about using the same setup. I have been researching it all morning, know I have to go to chemistry, sucks, lol
7 Second Club
Kyle
Kyle
thanks and you have a very beautiful setup.
stock radiator, stock fans with a stock water pump..havent gotten around to putting my evans pump back on. Not that theres been a need, but i spent 500+ on it so its going back on dammit
The link that the original poster put up is the exact one i should get? I know there is cuttin and **** involved but i wanna make sure i get the right one. Definatly a great mod!
John
John
From what I know the stock Lt1 radiator is better, but are they the same size. I think the stock rads are about 2.5-3inchs Longer and about 2inches taller.
What I am thinking is the stock rad and fans can be used in a Vertical setup?
Plus I was looking at summit and found these 3 rads with the same demision. The bottom one is the one with the link at the top, the other 2 look identical besides a 1 1/4 opposed to a 1inch Tube size.
http://store.summitracing.com/egnsea...+115&x=22&y=10
the car was sitting on the ground when i cut out the core support and it didnt flex at all. wit hthe k member bolted up and the lower support still in its plenty solid. i just marked it off and used a cutoff wheel cuz thats what i had at the time. im sure there may be an easier way to actually cut it though
Bringing this back, Kyle what is the part number for the Fan and shroud and where did you get it. I have a Daily driver and I plan on using that same radiator.
Your single seems to be working Fine.
7 Second Club
Kyle
Kyle
