What pushrod length did you use on MS3/LS6 Heads
Old 10-17-2006, 11:35 AM
SPLATT's Avatar
Default What pushrod length did you use on MS3/LS6 Heads
IF anyone has done this swap, which i know there are many haha. im looking for a little help. what pushrod length would i use on a MS3 and PRC LS6 Stg2 heads. I would like to keep the valvetrain noise to a minimum. but i figured id ask here first since there are alot of ppl with this or very close to this type of setup. Thank you in advance!
Old 10-17-2006, 11:44 AM
Xtnct00WS6's Avatar
How much are you milling?
Also, how much smaller is the base circle on your cam than stock?
