A little help....please
I have an 01 SS. Well its inspection sticker time and I cannot get rid of the knock sensor code. Ive deleted them a couple times and it comes right back. Can anyone help me?
Originally Posted by cerebrex
What does it say? Does it say low input or what?
And also Im in Conroe TX, sorry I left that out.
Guess I left some more info. out. Sorry guys, the car has some upgrades cam being one of them, I really think this is what is sending the bad code. I tried to replace it when i first got the code, but after about 10 miles or so it came right back on. that was almost a year ago, i havent tried again since. I guess I'll try that again tomarrow.
When you put the intake back on (guessing you took it off), I bet you pinched the knock sensor cable that hooks into the harness. It goes under the intake through a channel to the knock sensors, and it's easy to pinch if you don't pay particular attention to it. A new cable is cheap, and will fix it if that's the problem. Go to Autozone and have them read the codes. If it's low input on bank 1 and 2, that's your problem.
