can i make my ls1 into a ls7
Old 10-17-2006, 05:36 PM
white_ls1z28's Avatar
Default can i make my ls1 into a ls7
Does anyone know were i can get a kit or package that will turn my ls1 into a ls7,or is there not one??
Old 10-17-2006, 06:51 PM
HottLS1Z's Avatar
I dont think the stock block can be bored enough to make a 427ci.
Old 10-17-2006, 06:57 PM
3.4camaro's Avatar
go take a look at what MTI is doing. they bore to 427.
Old 10-17-2006, 06:58 PM
2001bluerata's Avatar
On a LS2
Old 10-17-2006, 07:40 PM
1320 killer's Avatar
yes, MTI is boring to a 427 but using a LS2 block and no, the stock 346 cannot be bored to a 427.
Old 10-18-2006, 08:59 AM
TeEnAgE pHeNoM's Avatar
I read in a magazine that the LS1 block could be made into a 454?
Old 10-18-2006, 09:59 AM
WS6NIGHTMARE's Avatar
The LS1 block can be taken to 427, and I think 343. The LS2 is getting as high as 455 now I believe.
As for a turning your LS1 into an LS7, cant happen. The heads are too big for the bore of an LS1, period. Just throw on some LS6 parts and have fun. The new LSx motors are great, but the old one still hold water damn well. No need to feel outdated........yet.
Old 10-18-2006, 10:16 AM
Billdog350's Avatar
You can throw a nice twin turbo or supercharger setup on there for less than a LS7 conversion would cost you. If you want good power for $2000, throw some ported PRC heads and a proven cam in there and you'll have an additional 70-100hp and 50-80ftlbs at the wheels.
Remember a nicely modded LS1/6 is going to be close to PEAK hp/tq of the stock LS7...except you're giving up some low end grunt.
Old 10-18-2006, 10:18 AM
DAVESS02's Avatar
Darton MID sleeves at a cost of around $3000 installed with a 4.125 bore and a 4.00" stroke will get you there.
Old 10-18-2006, 11:32 AM
I was under the impression that the ls1 346 could not go above 400 c.i. thanks for the schooling
Old 10-18-2006, 12:01 PM
Ferocity02's Avatar
Max bore on LS1 block is 3.905". You can sleeve them though to a bigger bore, but it's not cheap.
Old 10-18-2006, 12:33 PM
pianoprodigy's Avatar
Yep, $19.99 kit and it turns into an LS7!
www.igottabridgetosellyou.com
Old 10-18-2006, 12:35 PM
Bad30th's Avatar
Epoxy !
Rob (Bad30th)
Old 10-18-2006, 01:01 PM
staringback05's Avatar
hmmm or just buy the complete crate motor from gmpp.....better start saving
Old 10-18-2006, 08:17 PM
ssfast99's Avatar
actually the ls block can get up to 468 ci with the new head spacer. you change the sleeves and custom crank clearence along with a deck spacer that aliagns the new sleeves. some real cool stuff going on with the ls block. a 427ci is not worth it compared to a 408 ci because the smaller stroke the higher rpm can be reached.
Quick Reply: can i make my ls1 into a ls7
