Can I use this for the alky kit?
Old 10-17-2006, 09:39 PM
LSs1Power's Avatar
Default Can I use this for the alky kit?
I couldnt find straight alky around the area, but found this bottle which contains 98% Methanol. Can this be used instead?
Old 10-17-2006, 10:43 PM
Turbo Addict
RICE ETR's Avatar
Where in VA did you get that stuff?
As long as there isn't any glycol or the like, you should be ok.
Old 10-18-2006, 10:48 AM
TchargedLS1TA's Avatar
Looks like Heet.. I wouldnt use it, too many chemicals designed to be used in conjunction with gas to prevent dissipation. Snow Performance sells their "Boost Juice".. Its not straight meth, but works pretty well..
Old 10-18-2006, 02:41 PM
Turbo Addict
RICE ETR's Avatar
When i haven't been able to get meth, i would use HEET or a mix of it and washer fluid....seemed to work fine for me. What else is in it? I thought it was 99.9% meth. No?
Old 10-18-2006, 03:39 PM
LSs1Power's Avatar
It doesnt say whats else is in it.
Old 10-18-2006, 03:44 PM
anarchy99's Avatar
what about going to home depot and getting a jug of denauterd alchohol and mixing it 50/50 with water?
Old 10-18-2006, 03:54 PM
Im not 100% sure, but I beleive it has dispersing agents as well as chemicals to help it mix with the gas..
Quick Reply: Can I use this for the alky kit?
