questions about twin in tank walbros
No that harness is made to run both pumps with a higer amp relay. Which is usally ran off the ALT and the old source for the pump will close the circuit on the contact side of the relay.
Originally Posted by 98turbls1
So just relay it in to pull a higher current from a new source (battery, alt, or whatever) and then have the old wire as the switch...Correct??
